Electric pop top
popeyemth
Have a crank up pop top on our Shadow Cruiser truck camper.Would like to convert to an electric motor to crank it up. Anyone have info links or knowledge about this please speak up. I'd hate to have to quit using this great camper but it's hard on my body to crank it up.
Sorry for the poor picture
Thanks,Mike
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
5 REPLIES 5
whizbang
Have you kept your lift system lubed?
For years I did the annual spring maintenance on my lift system, but got busy and out of the habit 2 or 3 years back. A couple weeks ago, I noticed that my roof was very difficult to crank up.
After I lubed with silicone spray, it flew right up.
+1 on the longer extended crank handle and/or the electric drill.
Whizbang
2002 Winnebago Minnie
http://www.raincityhome.com/RAWH/index.htm
Steve_in_29
Since 2007 or so Outfitter went with a power roof that uses a modified jack motor. The motor is mounted at the end of the mechanism's screw drive. It does make working the roof effortless but also MUCH slower. No pictures as I would need to disassemble part of my camper to get them.
If you go with a drill ENSURE the drill has a low-speed/high-torque setting and that the drive gear is fully meshed as you will quickly wear it out otherwise.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
cewillis
Here's what I did to approximately half the crank effort needed. Combined a spare roof crank and a spare jack crank - grinding the jack crank shaft to fit very tight into the roof crank shaft tube.
The longer crank just barely clears when starting to crank the roof up, and when finishing letting it down.
Cal
_DJ_1
Someone here posted earlier of a crank handle they made. He extended the handle quite a bit for more leverage. I think he could have gone into business from the amount of us here that wanted one. I was also thinking of doing that. When my canoe and other stuff are on the roof those first couple of cranks are getting brutal!! I would buy an additional crank and take it to a welding shop for a longer handle, keeping the original for a spare.
I would not use a power drill. These gears are not the most robust and fear they won't last long with that much torque and speed.
FWIW Northstar has come out with a power top on some of their models.
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
Old_Days
I would use a 20 volt cordless 3 speed drill. Then see if you could buy a bit that you could use,or cut the handle off.
