โDec-23-2014 05:58 AM
โDec-29-2014 07:46 AM
โDec-29-2014 07:33 AM
โDec-29-2014 07:24 AM
โDec-29-2014 06:22 AM
โDec-29-2014 03:40 AM
RinconVTR wrote:Ron Gratz wrote:RinconVTR wrote:For the 4-Point Equal-I-zer hitch, the majority of the sway-resisting torque is generated at the contact surfaces between the socket and hitch head.
Do not lube the bars at the L brackets as this IS your sway control for this WDH design. Decrease friction at the L brackets, decrease sway control. The two are directly related.
The friction force generated at the L-brackets is a relatively small amount.
Ron
You obviously have never owned one, or you would not state such non-sense. The ball sockets are indeed defined at part of the "4 point" system, but have little to no effect on sway in reality vs marketing.
The ball sockets (trunnion knuckles) allow the trunnion bars to articulate left to right, they DO NOT resist trailer sway at all. Driving in a straight line, there is ZERO movement at the ball sockets. Sway control on such systems like the E2 and Equalizer is 100% on the L brackets.
In fact, you have done a few calculations (that I am not in 100% agreement with) regarding forces at the ball with WDH applied that could also be used to estimate forced at the L brackets or chains. There is great force on those bars at the L brackets, and I cannot believe you of all people think metal on metal friction in the area contributes less than lubricated ball sockets that hardly move when trailer sway occurs.
Ever notice that out of the box, the friction area on the bars that meet the L brackets is unpainted? But the ball sockets and all of the trunnion head (hitch) are fully painted? Hmmm. That alone should tell you all you need to know.
โDec-28-2014 07:08 PM
Ron
โDec-28-2014 09:48 AM
โDec-28-2014 04:51 AM
โDec-27-2014 05:58 PM
nohurry wrote:lbrjet wrote:
The Equalizer 4 point hitch is designed to be lubed (and should be lubed) on the top and bottom of the hitch head sockets. Says so right in the manual. I lube mine liberally at least every 500 miles, most of the time before each time I tow. I have 16,700 miles on this hitch and follow what it says in the manual, not what some people say on here. Loosen the bottom nut until the socket swings freely, lube the contact points and then torque to 50-60 ft lbs. I use 60, some people use more and some people use less, use whatever works on your hitch.
This.
If your equal-I-zer is set up properly, and you lube the top and bottom of the bar socket areas, the noise is minimal. I love mine, very effective integrated WD, and sway control.
โDec-27-2014 05:55 PM
cmoecmoe wrote:downtheroad wrote:
Someone above advised you to grease all the contact points....I would not do this as it will keep the sway components from doing their job.
You can and should grease the hitch ball and the trunnion bar ends that attach to the hitch head....but not grease the trunnion bar ends that contact the saddles.
From the manual... "Lubricating the socket joint may help reduce this noise, and is part of the required regular maintenance routine. Lubricating the L-bracket joint is optional. A better solution is a set of official Equal-i-zer brand Sway Bracket Jacketsโข. They quiet the ride without the mess of using a lubricant.
The noise is also addressed on the FAQ section of their web site. http://www.equalizerhitch.com/Equal-i-zer%20Support/faqs.php
Craig
โDec-27-2014 05:19 PM
โDec-26-2014 06:31 PM
โDec-26-2014 04:46 PM
โDec-26-2014 07:27 AM
โDec-26-2014 07:25 AM
cmoecmoe wrote:
You can use lithium grease to lube up all the contact points and it will help with the noise. They all groan/pop and make noise as there is a lot of pressure there to "level" out the trailer/tow vehicle.
Merry Christmas to All!
Craig
