Equalizer Hitch
SgtMark
Forgive me for not knowing the correct terms but the hooks that are located on the tongue of my TT that the equalizer chains hook to are not even. One is positioned about three inches further back then the other. It was like that when I purchased it. My question is do I need to move one to match the other or is the position of both ok to pull.
Thanks
8 REPLIES 8
SgtMark
Thanks everyone, I will hook up my TT this weekend and do some measuring and place the saddle brackets correctly. The season is upon us and I do not want to be grounded by poorly maintained equipment lol.
beemerphile1
Thanks
What does the manual for your hitch say? If you don't have the manual, you can find it online at the manufacturer's website. They probably should be close to equal distance.
To avoid confusion; Equal-i-zer is a brand of hitches but in general they are called weight distribution hitches.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
SoundGuy
Both frame saddle brackets should be sitting the same distance from the coupler and set so both chains are vertical. Any other setup is incorrect.
2012 Silverado 1500 Crew Cab
idaho556
They should match , I'm wonder if you have two different bar lengths, usually the bars are the same length
JayGee
They should be the same distance from the ball if possible. But I doubt that it would be much of a problem, if any, if they are off a little. If it levels up the trailer and tow vehicle then go with it.
But I am open to correction from those with greater knowledge. ๐Ÿ™‚
Jaygee
2005 Bounder 35E on F53 chassis
WayneAt63044
When moving them, consider if anything like LP tank placement would interfere with the pipe motion used to tighten the chains.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
3oaks
They should match each other (equal distance) from the ball. As to which one to move is the question, or perhaps both need to be moved so that the chains are vertical when hooked up.
downtheroad
If I am seeing what you are describing....(posting a picture would really help).
The chains should be vertical when you are loaded for a trip and all hitched up...if not, adjust the snap-up brackets as needed.
If this is your hitch...then the chains on this one look about right.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
