Fast Gun issue?
Pete_k
The fast Guns came up short yesterday. They were about 2" short of reaching my Torklift frame mounts on the front. The rear fit without any issue. But on my 2022 ram 3500. Its like the frame mounts put the receiver lower then it needs to be. Thus the front when extended all the way. Still is short.
Has anyone added a couple of links of chain to the Receiver section?
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
12 REPLIES 12
Pete_k
joerg68 wrote:
+1
I have been using them like this since 2009. Ensure that they are mounted with gravity pulling the nut into the closed position.
Thanks for the photo.
Pete
2016 Eagle Cap 1200
joerg68
Nomad III
Nomad III
+1
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
Pete_k
kohldad wrote:
Just use the links mentioned by 3 tons. They won't come loose if they are snugged with a wrench. I've been using them for 7 years cause needed them when I upgraded from a 2004 to 2015 Ram. They are just attached to the Torklift frame mount insert and stay on all the time.
Have a bunch of those. But the kind I'm using no issues removing easy. Also both are rated for more then they should ever see. But always go big or go home.
When we bought our 2006 Okanagan. Those 3 tons shows were on them. As with it only got chain and turnbuckets. Now own 2 sets of Fast Guns.
2016 Eagle Cap 1200
kohldad
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Grit_dog
Navigator
Navigator
^Thats completely overkill for what you’re doing. It’ll work, of course, if that will hook to the mount on your truck.
Pete_k
d3500ram wrote:
Pete,
...if you use the add-a-link component, be sure that they don't back off the threads and open up while driving (you want the "O" shape, not the "C" shape.)
If it opens up, the integrity could perhaps be compromised.
I plan on using Chain Clevis to mount the chain. That way it can't come loose.
2016 Eagle Cap 1200
d3500ram
Pete,
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Pete_k
Thanks Guy's.
Going to just add 2 links to and let it ride. Friday I removed 2 of the clevis shackle off the Super hitch 4ft extension. That give me just enough room to make it work.
Pete
2016 Eagle Cap 1200
Grit_dog
Navigator
Navigator
Adding chain works. Had chain on ours for years. No fastguns
Or you could cut and add a longer piece of all thread with a coupler nut if you want a more permanent setup.
d3500ram
I have done it when needing to set-up the SB camper on a LB truck, used the add-a-link as 3T mentioned above at the TL end and more than a few chain links along with a zip-tie to keep the excess from dangling:
fpoole
... and that's probably the easiest, cheapest way, but Torklift has longer ones unless it's really long... you just unscrew it and screw in a longer on if I recall.. been a while ao, but I 'Think' that works..
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
3_tons
I had the same problem…Just add a couple of ‘add a link’ chain link extenders on each side:
https://www.homedepot.com/p/Everbilt-1-2-in-Zinc-Plated-Quick-Link-43884/205887941
3 tons
