Dec-23-2021 02:41 PM
Jan-11-2022 01:47 PM
Grit dog wrote:JRscooby wrote:
Do the pucks have threaded holes? If so, cut head off bolts and screw them in. Tap cardboard or mat (plywood?) with hammer, this would make marks for center.
You may want to look up what a “puck system” is in these newer trucks.
Jan-11-2022 12:34 PM
Jan-04-2022 07:50 AM
Jan-04-2022 06:27 AM
Jan-04-2022 05:37 AM
Dec-28-2021 07:14 AM
rhagfo wrote:StirCrazy wrote:Pete_k wrote:
I'm thinking lift up one side at a time. Put red lipstick on the bed cover lips. Then lay the mat back down. But have a section of Vinyl floor in the shop.
I would just lay it down the crawl under with a sharpy and mark the holes from the bottom. it will take a bit of work but then nothing is out of place
Steve
The holes have the puck sockets under them, not easily accessible.
Dec-25-2021 04:51 PM
Steve
Dec-25-2021 04:21 PM
Dec-25-2021 07:41 AM
Pete_k wrote:
Bed mat will be 3/16" for that reason. With the picture frame in the truck. A 3/16 piece of lexan, just fits. I can adjust the pucks to take care of some of that if need be.
I'm thinking lift up one side at a time. Put red lipstick on the bed cover lips. Then lay the mat back down. But have a section of Vinyl floor in the shop. Its 5ft by 10ft. Thinking I will use it as a template. Get everything right, then use to it to drill the holes out.
May have to pick up a 4x8 1/4" mat Monday. If I buy the camper were going to look at. To get it home on. If so they also have a 5x8 mat. May just buy it and cut to fit the truck. AS the DEZ-DZ86916 - Dee Zee Truck Bed Mat has been moved back to Mid Jan now. So if I go this route. I will cancel that order. They told me yesterday It would not be an issue if I did not wait until Jan to cancel that mat.
Dec-24-2021 04:32 PM
Dec-24-2021 11:51 AM
Dec-24-2021 07:38 AM
Dec-24-2021 06:54 AM
zb39 wrote:Same is true for the Ram "picture frame adapter", too. Some clearance between the bed and bottom of the adapter, but not a lot.
If your mat is to thick the B&W hitch may not work.
Dec-23-2021 06:05 PM
