โAug-12-2022 06:24 AM
โAug-18-2022 01:23 PM
Latner wrote:
It's probably just me, but the snarky responses don't help.
โAug-18-2022 09:05 AM
mkirsch wrote:Latner wrote:
Instead of asking for help with fender flares on a RV tow vehicle forum, why not go to one of many actual truck forums where you will probably get answers to your questions...or make a few phone calls to some of the sellers of said fender flares, geez :R
Because this is a TOW VEHICLE forum, and people here accessorize their tow vehicles. I'm asking about an accessory for one of my tow vehicles to make it look better, but as per usual, everyone is hung up in the "why."
I was hoping it might be a refreshing change from the typical Ford vs. Chevy vs. Dodge, Gas vs. Diesel, my 1/2 ton will tow a space shuttle vs. you need a 1 ton dually to tow a roller skate arguments. Oh and the 768 page discussions about how electric will never be any good.
The "actual truck forums" were much worse.
Vendors sell thousands of products. You can't expect a phone operator working for minimum wage to know every detail about everything they sell. Everything the vendor knows about the product is on the website. Besides, they're not going to tell you that anything they sell is poor quality, difficult to install, or won't meet your needs. It's called real world experience.
So, thanks for well, nothing, everyone. Back to your regularly scheduled program.
โAug-18-2022 07:48 AM
โAug-18-2022 07:43 AM
โAug-18-2022 05:38 AM
โAug-17-2022 02:38 PM
โAug-17-2022 11:06 AM
mkirsch wrote:
Grit, old buddy old pal,
This isn't my first rodeo. You can grind and sand and wire wheel and paint all you want but you are only covering up the OUTSIDE.
You can't get to the INSIDE, which is where it's rusting from, without cutting out the old metal.
Once the paint is blistering on the outside, it's rusting through from the inside.
...and that's EXACTLY what I want, someone to say, "Hey this Brand X are easy to install and they cover up 2.5" from the edge of the wheel well opening." Even someone to say, "Hey, this brand X is easy to install and are a great value for the price." You don't need to know how much I want to repair.
For such a smart guy you are having a tough time wrapping your head around such a simple question.
โAug-17-2022 10:59 AM
โAug-17-2022 09:10 AM
โAug-16-2022 08:15 AM
mkirsch wrote:Grit dog wrote:
I presumed it was just surface rust bubbling the paint, not rusted through.
Not sure which google you're using, but the "5000 different options" are really like a dozen different styles from 100 different vendors, lol.
Although, I'm confused, you first said you were planning in "fixing" the rust (presumably not with a good finish or color matched, hence the need for flares) and said you were looking for something you liked.
Then you said you're just slapping them on to cover up the rust to sell it.
If the latter is the case, buy the cheapest ones you can find and add a for sale sign to your order and let er rip.
PS, still think the bushwhacker type wide flares look awkward with OE size wheels and no lift, so I'd go with skinny OE style looking flares.
It is surface rust but surface rust means it's on the verge of rusting through. Sanding it down and painting it will buy me 6 months max. To do it properly I would have to have the old metal cut out and replaced.
I fail to see anything contradictory about my statements. Yes, I plan on doing some sanding and slapping on of paint, probably black POR15 because I have some leftover from another project. Then I want to cover up the rust with fender flares, because despite my sanding and paint, the rust is still there.
This way if questioned I can honestly say I "fixed" the rust before adding the flares, because that's how you "fix" rust in car salesman world.
I agree on the Bushwacker flares, and would never install those. I just want something quick and easy and cheap that will cover up the rust. Impossible to tell from the pictures if they will cover up the rust, or how easy/hard they are to install, or if they even fit decent out of the box.
โAug-16-2022 05:53 AM
Latner wrote:
REALTRUCK
โAug-16-2022 05:48 AM
โAug-15-2022 10:32 AM
โAug-15-2022 07:43 AM
mkirsch wrote:
Define "properly." If I were to fix it PROPERLY, the rusty metal would be cut out and replaced with new, painted to match, and I would not want or need fender flares to cover anything up.
That's going to cost me a few thousand dollars, which I do not have or want to spend on this truck. It has already let me down twice in the last 1000 miles with stuck lifters. I just want to cover up the rust and pawn it off on some unsuspecting car salesman.
