โApr-21-2019 01:17 PM
โApr-24-2019 02:23 PM
Geewizard wrote:
Yes.
Of course, my TC doesn't have three slide-outs, a master bedroom with walk-in closet and shower for two, or a hot tub. ๐
โApr-24-2019 05:44 AM
trail-explorer wrote:desertfoxjr wrote:
What has been your experience getting a flat on a SW Truck while carrying a TC>
What's an SW truck?
RAM 3500 Crew Cab 4x4 DRW
Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWRHonda EU2000
โApr-23-2019 05:53 AM
โApr-23-2019 04:49 AM
โApr-22-2019 07:54 PM
โApr-22-2019 05:30 PM
โApr-22-2019 01:40 PM
What's an SW truck?
โApr-22-2019 11:48 AM
โApr-22-2019 11:47 AM
โApr-22-2019 11:16 AM
โApr-22-2019 10:23 AM
Buzzcut1 wrote:
had a rear tire blow out on my SRW with a 4600 pound lance 1055. The blow out and getting the rig safely stopped is the issue. Changing the tire isn't. As long as you have a good bottle jack ( not the OEM Jack) changing the tire with the camper on or off is the same thing. loosen the lug nuts, drop the spare and pull it out. jack the truck up remove the lug nuts and flat. put on the spare tighten the nuts lower the jack, torque the lug nuts stow the flat and off you go.
โApr-22-2019 10:04 AM
โApr-22-2019 07:13 AM
wnjj wrote:JimK-NY wrote:
Don't plan on using the OEM jack to lift the rear of the truck with a fully loaded camper. You should plan on releasing the hold downs and using the camper jacks to handle at least some of the load.
I didnโt even release the tiedowns. Just alternate camper jacks and truck jack so the suspension stays loaded.
โApr-21-2019 11:22 PM
