Oct-16-2014 03:18 PM
Oct-17-2014 09:44 PM
Oct-17-2014 05:47 PM
Oct-17-2014 05:20 PM
Merlisk wrote:RJS3 wrote:
I may be missing something here but, you should be able to tow the Thetford Portable Tank using your hitch and the handle on the portable tank.
Of course what you suggested would work IMHO it would be time consuming.
Well, I do that now, but the problem is that sometimes the dump is quite some distance away from the RV, and it seems like everyone's watching me drag it. 🙂
Putting it in the back of the truck just seems easier to haul.
Oct-17-2014 04:42 AM
Merlisk wrote:
That's a much cheaper alternative for sure. According to the manual, it says "Do not use the pump for other fluids, especially not fuels, cleaning fluids, or other chemical products." Have you had any issue with pumping the gray water since it has cleaning fluids?
Thanks.
Oct-16-2014 09:02 PM
Oct-16-2014 07:30 PM
Merlisk wrote:
... According to the manual, it says "Do not use the pump for other fluids, especially not fuels, cleaning fluids, or other chemical products." Have you had any issue with pumping the gray water since it has cleaning fluids?
Oct-16-2014 06:30 PM
mbopp wrote:
I've used one of these to pump gray water. Use one of these and some recycled garden hose to get the gray water to your tank. It's not as fast as a Flojet but it's cheaper.
I have a surplus 30-gallon barrel strapped in the truck bed to transport the gray water. Way cheaper than a tote. It was set up with a garden hose connector and 3/4" ball valve but is getting re-worked for an 1-1/2" RV waste valve & hose.
Oct-16-2014 06:12 PM
Oct-16-2014 05:52 PM
Oct-16-2014 03:26 PM
