Mar-23-2014 07:47 AM
Mar-25-2014 05:31 PM
Mar-24-2014 06:31 AM
NRALIFR wrote:
The '08's do seem to have the most cooling system problems, I noticed that myself when I was looking for an '08-'10 F450. Several updates to the upper and lower rad hoses, the radiator itself, the T-stats and plumbing changes between the '08's and 2010's.
If you choose to do the replacement yourself, be aware that it's nearly impossible to get all the air out of the system without using a coolant lift. The Ford Shop Manual specifies using one on the 6.4, and you should definitely invest in one and use it. There are cheaper ones out there, but this is the one I have.
Mar-24-2014 06:28 AM
Golden_HVAC wrote:
Dennis,
Have you installed a water coolant filter on your truck yet? It really helps the longevity of the 6L and 6.4L Diesels. It will help any vehicle, and I put one on my motorhome when it was new in 97, even though it has a 460" gas engine.
Napa part # FIL 4070 is the filter, and FIL 4019 is the filter holder that connects into the heater hose lines. Some have added a 3/8" close coupled ball valve, so they do not lose any coolant while changing the filters. I put mine just behind the bumper, where I can put a 5 gallon bucket to catch any excess water leak while changing the filter.
By keeping the filter clean, then the minerals are not being pumped around the system, sticking to the radiator or oil cooler, and will lead to a much longer water pump life, no need to clean out the radiator, or change the coolant every few years.
In the 6L and 6.4L diesels, clogged oil coolers can lead to water getting into the engine, causing a $15,000 engine replacement. You don't want that. The water filter prevents the clogs, and solves the problem.
Fred.
Mar-24-2014 04:43 AM
Mar-23-2014 08:34 PM
Mar-23-2014 07:13 PM
Golden_HVAC wrote:What Fred said, though $15K is the WORST case. Casting sand from the manufacturing process can clog the oil cooler, starving the EGR cooler of water, which causes the EGR cooler to rupture and introduce water into the intake manifold. A coolant filter is cheap insurance, costing less than $150 for a good kit from a firm like DieselSite or BulletProof diesel. The 6.4 engine is an upgraded 6.0 engine with different injector and turbocharger setups. For either of those engines, changing filters and fluids religiously, as well as putting the engine to work is the key to long engine life.
Dennis,
Fred.
Mar-23-2014 01:21 PM
Mar-23-2014 12:08 PM
Mar-23-2014 10:52 AM
Porsche or Country Coach!
Mar-23-2014 08:44 AM
Mar-23-2014 08:40 AM
Mar-23-2014 08:32 AM
