โFeb-05-2019 04:55 AM
โFeb-09-2019 09:17 AM
โFeb-09-2019 09:14 AM
carringb wrote:
The high-amp alternator in the V10 was a 225-amp, not 400 amp.
โFeb-09-2019 06:55 AM
rjstractor wrote:Groover wrote:Big Katuna wrote:
Dual alternators have been an option for years. My boss had it on is 6.0 Ford Diesel to run an inverter.
Is this a diesel? I assumed that it was the new 7.3 gas engine that the thread is about. What would be new here is not "dual alternators" but that a gas burner is targeting markets that require dual alternators, typically commercial markets.
Nothing new really, the 8.1 GM V8 and Ford's Triton V10 were used extensively in commercial markets. I'm not sure if they offered dual alternators on the V10 though, our E450 ambulances have a single aftermarket alternator rated at around 400 amps.
โFeb-09-2019 06:24 AM
โFeb-09-2019 04:43 AM
โFeb-08-2019 05:34 PM
โFeb-08-2019 04:37 PM
FishOnOne wrote:
We bring you.... Godzilla! :C
โFeb-08-2019 04:36 PM
carringb wrote:Groover wrote:
On my 15 passenger van version the first step in changing the spark plugs is to lift the body off of the frame to get room to work.
What?!? What service manual told you to do this? I have never done this, and have changed my V10's plugs 4 times myself.
โFeb-08-2019 01:36 PM
โFeb-08-2019 07:53 AM
โFeb-08-2019 07:18 AM
โFeb-08-2019 05:22 AM
ib516 wrote:Atlee wrote:
However, as an option, the 6.2L can be mated to the new 10 speed transmission.
On edit:
You are correct, I was wrong.
"The big differences are under the hood. First, the existing 6.2L V8 continues with a 6-speed automatic transmission for the base trucks. You can opt for the new 10-speed automatic transmission for the 6.2L V8, the all-new 7.3L V8, and the updated 3rd-generation 6.7L Power Stroke turbo-diesel V8. This is a total of four powertrain combinations."
LINK
โFeb-08-2019 04:51 AM
โFeb-08-2019 04:47 AM
Atlee wrote:
However, as an option, the 6.2L can be mated to the new 10 speed transmission.ib516 wrote:patperry2766 wrote:
maybe I didn't catch it....but is it replacing the 6.2L completely or is it an optional engine in addition to the 6.2 & 6.7D?
The 6.2L stays as the base engine in an F250 only, and comes mated to the 6 speed auto. The 7.3L and 10 speed will be the base in the F350 and up.
