Ford F-350 switches
53_willys
I just purchased a new F-350 Powerstroke Lariat 4x4 crew cab SRW , my question is where do you hook into the auxiliary uplifter switches ? Back of the switch, fuse block ? I thought I'd ask here before having to deal with the local dealership.
6 REPLIES 6
53_willys
Thank you for the info guys much appreciated.....Dan
Campinfan
My 2008 f250 has a set also under the hood in addition to the one by the steering wheel. The one under the hood is in front of the driver's side from what I remember.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Denny___Jami
Remove the panel below the steering wheel and the side cover on the side of the dash and you will find them straped to the wiring harness, different switches have different amperages.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
Dave_H_M
As I recall that was covered in my ops manual. The switches are not sll the same amperage.
Also i think all of mine are not energized when the key is off.
Mine were all stubbed off,color coded and located above the kick panel that is directly under the steering column
Tiger4x4RV
This YouTube video doesn't jiggle the camera as much. The first one gave me a headache. This one also gives the webpage address for an official Ford wiring diagram.
https://www.youtube.com/watch?v=K1ZAcR46_28
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
agesilaus
There are some wire stubs in the driver's foot space. At least they are in my 2012 yours may be different. Look at this search result: wiring
YouTube
Official Ford pdf
The switches are not the same, some go thru the ignition and are cut off when the truck is off and some do not.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
