Sep-10-2018 06:20 PM
Sep-12-2018 02:17 PM
Sep-12-2018 08:16 AM
LarryJM wrote:
I used a single friction sway bar for 25 years on my last trailer that was 26' and weighed 6K and was towed with an E-250 Ford Van weighing around 7500lbs normally.
I even wore out one after about 20 years and around 100K miles towing. With that said all the rest of this post is both a mixture of what others recommend and my experiences and opinions so take it in that vein.
1. Not sure about when two friction sway bars would be needed, but for my setup I felt one did the job just barely, but had to be set ultra tight.
2. As far as I know the only way to tell if a friction sway system is adjusted correctly is to "TEST IT ON THE ROAD". One has to remember that all a friction sway system is is basically an over tightened drum type brake that is continually dragging.
The "adjustment screw" sets the force that the two brake pads "squeeze" the bar when the lever is fully tightened. This "stiffens" up and dampens the rotation of the trailer tongue on the ball of the hitch.
In my experience you need to "test" it's effectiveness just about every time you get out on the road for the day since over time the "applied dampening force" is continuously being lessened from the pad wear due to the both the natural movements of the trailer and those induced from outside forces like TV maneuvering, passing semis, wind, and road surface irregularities.
Now on to the "TESTING" and "ADJUSTMENT".
I have never seen nor will I think you find any definitive procedure for adjusting and testing a friction sway system since I think no manufacturer or entity will put it in writing because of libelity concerns since it requires doing things that can be inherently "UNSAFE" if not done very carefully.
This testing and adjusting is all done basically "BY FEEL" and is totally dependent on the specific TT and TV combo and purely a judgement type assessment.
First one needs a decent "baseline" w/o any "anti friction" system installed.
I did this by taking the combo out on the road on a section of deserted divided highway and once at a steady speed of around 40mph did a series of "snake type" maneuvers where I got the trailer moving off axis from the general direction of travel and then stopped the off axis travel and watched the "tail of the trailer" in my rear view mirrors.
What one is looking for what speed and amplitude of the "snake" will cause the tail of the trailer to swing back and overshoot the centerline a little and then quickly "die out" and again fall directly behind the TV in the direction of travel.
I wanted a fairly large "single overshoot" of the trailer tail. Here one has to be careful and if you see the tail of the trailer overshooting the baseline multiple times or easily something else is wrong and needs to be fixed since the natural tendency should be for the "tail swinging" to die down fairly quickly, with almost no multiple "overshoots" from a single maneuver.
This entire scenario if repeated with the sway system installed and tightened down, but not all the way. Here what one is doing is getting a feel for how the friction system will effect the trailer tail movements and overshoot.
It is now repeated for a third time with the system "fully set" (i.e. the lever fully tightened).
IMO what one is looking for is for the sway system to dampen the swing of the tail of the trailer to the point where finally at normal towing speeds (for me around 60mph) and with a decent single swing of the TV from one lane to say just over the centerline and immediately resume the normal direction of travel that the trailer would "swing back" in a single movement with "NO" or almost impreceptible "OVERSHOOT".
I was also looking for this swing to do so firmly and fairly smoothly. This is where the "adjustment screw/bolt" comes in and I found it needed a slight (generally less than 1/2 turn) adjustment about every couple of thousand towing miles depending.
I think I covered most of everything and in closing let me stress that I'm not recommending anything said above, but only passing on what I found to work and would caution anyone to be "EXTREMELY CAREFUL" when doing any abnormal trailer maneuvers especaily at speed.
Hope this helps and I'll be glad to elaborate if needed.
Larry
Sep-11-2018 06:40 AM
Larryzv7 wrote:
What is your opinion on having two friction sway bars, one on each side of your weight distribution hitch? I talked to a Camping World repair person who had never heard of two friction sway bars on a trailer while towing. But when I chat with someone from etrailer they advised that any trailer over 25 ft. might need two sway bars. I already use a weight distribution hitch and one friction sway bar but I still have a little bit of sway when towing my 2018 32-ft. Heartland.
I traded in my fifth wheel, which was very easy on towing and did not need a sway bar or a weight distribution hitch. But I’m thinking I want to put a second sway bar on my travel trailer. I understand that a number of factors can create sway, how your trailer is loaded, whether the distribution hitch is functioning properly, etc. I guess what I am asking is do any of you use two friction sway bars, and if so, does it work better than just having one?
An additional question is how much do you tighten your friction sway bar? Camping World told me to tighten it as tight as possible while online instructions say leave some play in the friction plate. I know I have to disconnect the sway bar when backing up but I’m not sure how tight I should make it.
Thanks in advance for your assistance.
Sep-11-2018 12:02 AM
marcsbigfoot20b27 wrote:
Sway depends on what you are towing, what you are towing it with, how the hitch is set up, how much tongue weight there is, etc. It’s different for everyone, but can be managed with proper setup if the physical numbers are good.
Sep-10-2018 11:34 PM
Sep-10-2018 11:33 PM
Sep-10-2018 07:50 PM
Sep-10-2018 07:08 PM
Sep-10-2018 07:00 PM
