Front end cap fade
moose308
What is the way to help eliminate front cap from fading?I am using Meguire's rv wax with uv protectant and 303.Anything better?
15 REPLIES 15
dsmith3
If it is gel-coat that fades then is the fading only a problem for fiberglass trailers/RVs? Are aluminum-exterior trailers not subject to this fading problem?
2015 Jay Flight 32 BHDS (Elite, Tech, Thermal pkgs)
1999 Ford F-250 7.3L Powerstroke 4x4 Lariat Crew Cab SRW 3.73
6.0L Trans Cooler
Gauges: EGT, Trans & Water temp, Boost
K&N Cold Air Intake
MBRP 4" Exhaust
Curt Class IV Hitch
P3 Controller
ProPride 3P Hitch 1400
B_O__Plenty
Duplicate post
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
B_O__Plenty
It's not defective paint that fades. It's the gel-coat. If you have painted end caps on your rig you should be okay. Mine were colored gel-coat and it started to turn white after only 2 years. had the front painted under warranty...now the rear is looking bad. Have to pay for this one. GRRrrr!
B.O.
Yup I'm a fanboy!
CaveRun
Here's where I keep my pontoon & truck camper.
Now have to get one for my 31' travel trailer! ๐Ÿ™‚
I have always waxed my campers/boats and that seems to help a lot!
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
hddecker
You are using two of the best products available for looking after your finish. I've used Meguire's and Protectant 303 it seems like for ever.
The caveat being if you have the defective paint, ain't nothing going to help that.
dsmith3
Have not owned a fiberglass trailer but am interested if the fading discussed is primarily an issue with just the front (cap) or if sides/rear also fade? Is it just the paint or are decals also prone to fading?
We were looking very closely at the Jayco Eagle but had concerns about delamination and fading.
6.0L Trans Cooler
K&N Cold Air Intake
MBRP 4" Exhaust
Curt Class IV Hitch
P3 Controller
EcoBullet
Mr. C wrote:
That's a nice cover. What are the dimensions?
Thank you! This one is 18 X 31 with 11 foot legs. Height is more than needed, but gives some growing room, just in case. Width is more than needed, but next smaller width is 12' and I'm not that good at backing. This also gives room for opening the slide and provides more shade for the sides.
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
Mr__C
EcoBullet wrote:
oughtsix wrote:
Best things to keep a trailer from fading in descending order. A garage, a car port, a trailer cover.
A carport has worked well for my boat (barely visible on the left). That's why I had one of these installed. The brown nose is pointing north.
That's a nice cover. What are the dimensions? I'm seriously considering doing this...I'd like to be able to pull thru it, but also would like 3 sides enclosed. Can't have everything...
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
Tequila
nice to have a heads up, I have a new brown nosed trailer. I bought a cover, but it will still spend 4 months a year in Mexico. I guess I will put 303 on it monthly down there.
EcoBullet
oughtsix
Best things to keep a trailer from fading in descending order. A garage, a car port, a trailer cover. In my experience there is no magic wax that is going to make a significant reduction in fading better than a cheap no name wax.
2006 Duramax Crew Cab Long Bed pickup.
2007 Coachman Captiva 265EX trailer.
ScottG
I tried everything to keep it looking nice but even the minimal sun we get here destroyed the finish.
I ended up getting a local shop (Ollies fiberglass repair in Lynnwood Wa.) to repaint it using a two part epoxy paint. That was three years ago and it still looks better than new.
It's a spendy solution (I paid $800) but the problem is permanently solved.
knshook
therink wrote:
What make, year and model is your RV? Several manufacturers have had issues with 2011 to 2013 models with colored front caps fading due to a defect with the paint used by the cap manufacturer. Keystone has been honoring warranty claims for this fading issue by repainting the caps.
This condition causes serious fading mostly on the upper portion of the cap.
I have a brown cap and don't appear to have this issue yet. I apply NuFinish polish on it every couple of months and it looks good.
We had this issue with our 2013 Dutchmen Denali. Fortunately for us we had a local dealership go to bat for us and we were able to have the front cap repainted at no cost. Many people who have had this problem have not been as lucky as we were,and it seems to be a best kept secret that there seems to be a flaw with the paint.
GilliedogKiwi
Interesting to read this. We just purchased a Jayco Eagle 266RKS which has a brown front on it. I'll have to pass this on to my husband. I know he has already waxed it with the McGuires. Thank you for the alert - we will keep an eye on it.
KiwiNZ - On the Road Again...
