Feb-24-2019 11:00 PM
Mar-06-2019 10:04 AM
Mar-06-2019 04:09 AM
Mar-04-2019 08:35 PM
Mar-04-2019 07:23 PM
Grit dog wrote:Please elaborate. Did the front end design change between 2002 and 2006?hedgehopper wrote:And your truck could not be more different than his. 2 completely different chassis.TCINTN wrote:Our 2002 Dodge 2WD 3500 dually was already acting up when we bought it with 18,000 miles on the clock. When we hit a bump at highway speeds, the front end would shake and the driver had to hang onto the steering wheel to keep the truck going straight ahead.
I have been watching this conversation because I have a 2006 3500 Dodge CDI SRW. I have 240,000 miles on it and I am starting to wonder when the front end is going to start acting up.
(This was while carrying our Northern Lite 10-2 CD. We have seldom had the NL off. So I can’t say what was the extent of the problem with the truck unloaded.)
As I wrote elsewhere on this thread, installation of a steering stabilizer kit solved the problem.
Mar-04-2019 04:53 PM
Grit dog wrote:hedgehopper wrote:TCINTN wrote:Our 2002 Dodge 2WD 3500 dually was already acting up when we bought it with 18,000 miles on the clock. When we hit a bump at highway speeds, the front end would shake and the driver had to hang onto the steering wheel to keep the truck going straight ahead.
Mar-04-2019 03:27 PM
Mar-04-2019 12:02 PM
Mar-04-2019 04:38 AM
Mar-03-2019 10:20 AM
HadEnough wrote:
Holding at 9:00 and 3:00 shaking against the toe.
You can see some movement in the lower ball joint doing that.
I was able to see that at the place trying to sell me a front end. Was able to shake it and see steering gear moving.
Mar-03-2019 09:39 AM
Grit dog wrote:HadEnough wrote:Grit dog wrote:HadEnough wrote:
I don't need to jack it up. I can shake the front wheel with my bare hands about 1/4".
I think I'm at 30-40k since last front end. Been driving all around the continent.
Coulda said that 6 pages ago! Jk.
sounds like they’re shot
Still. Isn't that a bit ridiculous?
$2000-$3000 of front end work every 30,000 miles?
Yes, it's absolutely ridiculous. I agree. Even with heavy wheels, rough roads, camper etc I'd expect more miles. Double that at least.
May have gotten cheap parts, idk.
Mar-02-2019 07:48 PM
Grit dog wrote:If the front end of your truck had the shakes the way ours did before I installed the steering stabilizer, I think all that shaking would accelerate the wear of the front-end components significantly.HadEnough wrote:Grit dog wrote:HadEnough wrote:
Mar-02-2019 05:56 PM
hedgehopper wrote:Grit Dog wrote:Wouldn't toe OUT cause the same wear as negative camber (on the inside edge of the tires)?
It could also have too much toe in and have the same wear (as negative camber).
Mar-02-2019 05:54 PM
Mar-02-2019 04:47 PM
