Sep-01-2020 08:22 AM
Sep-04-2020 06:37 PM
Sep-04-2020 06:18 PM
Sep-04-2020 06:06 PM
Geo*Boy wrote:HadEnough wrote:Geo*Boy wrote:
Very strange, my AF 990 doesn’t move period. I tension my Fastguns per Torklift spec’s.
It would probably move if your frame mounts looked like mine. Ha ha.
I have had Torklift frame mounts and Fastguns on two GM trucks and two different campers and never a bend or a broken weld on either of them.
I don’t like saying this but YOU are definitely doing something seriously wrong.
Sep-04-2020 05:45 PM
Sep-04-2020 05:12 PM
Sep-04-2020 04:55 PM
Sep-04-2020 04:46 PM
Sep-04-2020 04:11 PM
Sep-04-2020 03:34 PM
Sep-04-2020 02:41 PM
Sep-04-2020 12:24 PM
Kayteg1 wrote:mkirsch wrote:
IMHO the camper should stay in the bed simply due to weight and friction under normal driving conditions. I myself would not hesitate to take the tiedowns off my camper and drive around town. It would not move a fraction of an inch and I am not doing anything special to keep it there.
Normal driving in most of US cases include constant vibration (yes, I drove autobahns, where you could put coffee cup on top of dashboard and it would stay there at 200 kph).
When I set my new pickup, where front ties did have noticeable angle pulling camper forward, I gave it advised "5 yo girl" hand tension on fastguns. Over 500 miles driving, the camper moved about 1/2" to the rear.
I concluded that when vibration liquefy the friction, regardless factory bed mat, the air drag gives the camper significant pushing force.
I adjusted fastguns from 1/4" stretch to 1/2" stretch and camper did not move anymore.
Now OP is saying his camper is also turning on the bed, so sounds like he is not having side to side angle neither.
Sep-04-2020 12:14 PM
Sep-04-2020 12:13 PM
HadEnough wrote:
As far as the tension in the Torklift fastgun tie downs, it’s just right. Not loose and not cranked down super hard. They have a natural click to them at the right tension. They snap closed easily without too much force, yet they aren’t loose. Nice and snug.
Sep-04-2020 12:05 PM
wnjj wrote:
I have to agree with those who say you'll just be covering up the real problem by building different/stronger mounts. Something is way off to break welds that are basically in shear. As someone said, the camper mostly sits there and only needs some help to stay. If there's enough force to bust those welds either there is way too much tension on the tie-downs or not nearly enough, allowing the camper to leave the bed and "get a run" at pulling on the welds. If you switch to a one-piece belly bar, I suspect you'll start bending it unless it's really overbuilt.
Have you checked the truck's bed mounts? Since the camper sits in the bed but the mounts are to the frame any slop in the bed mounts could possibly aggravate the issue.
You haven't answered how tight you are running the fastguns? What method do you use to ensure the right tension?
Also, I'm really surprised you lost a rear mount with or without the camper. They are held by pins with spring-loaded retaining clips.
Sep-04-2020 11:56 AM
