front tire pressure
83trekker
Gonna haul my 9000lb 5th wheel with my 2500HD tires do 80 psi on truck, have the rear tires 80 psi what should i run the front?Never run the front full. What does everybody do?
5 REPLIES 5
TubaPete
dbbls wrote:
I run the pressure stated on the door jam.
Which for my '08 2500HD is 65 psi. As said, pulling a fifth wheel adds little to the front tires. In fact, for my set up the static load is the same hooked up or not.
Tuba Pete
edatlanta
When towing my 5'er: 80 rear, 60-65 front
When now towing: 60-65 front and rear
I have load range E tires as most 2500HD's do.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
goducks10
x2
Cummins12V98
80 rear and 72 front if it is a Cummins and 65 if GM or Ford. Cummins is heavier.
Run 45 in the rear. Leave the front towing or not. The front changes very little with a 5er.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dbbls
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
