Dec-16-2017 06:44 AM
Dec-18-2017 10:25 AM
Dec-17-2017 02:17 PM
Dec-17-2017 02:05 PM
path1 wrote:
We spent time with a retired Cummins engineer. Good guy with tons of good stories. His theory ..... OEMS's stretch maintenance schedules for as long as they can for sales reasons. (And bean counters always win, but really have no idea about the mechanics of a product and only think about cost of ownership compared to other OEM's) And consumers have no idea how long something has sat around or what conditions fluids or filters were stored in.
His advice...follow maintenance schedule but back up 10 percent. Example...if something is due at 10,000 miles to it at 9,000 (10,000 minus 10 percent) He loved fleetguard filters and Cummins anti-freeze but other fluids he said Ford fluids were as good as Cummins and more available on the road. The extras he did was...oil analysis (I forget how often) and he did an alternator "ripple" test every oil change. He packed elec connections with die-elec grease every couple years. He had a binder set up by component with the standard requirement and in front of binder he had a chart of when everything was due to his minus 10 percent method.
He showed me how to do the alt "ripple" test with volt meter. Which I now do. I really don't know if newer stuff needs it or not but my old one does. Pretty interesting these electronic machines on wheels:)
Dec-17-2017 01:37 PM
Dec-17-2017 12:43 PM
ShinerBock wrote:Turtle n Peeps wrote:
I'm super glad my engine maker does not require or even recommend a fuel additive. In fact, they recommend only using clean #2 diesel fuel so that's all I have used for 11 years.
It seams that GM may want to take a second look into that....
Bad advice in Duramax Manual
However, it seems from this bulletin that they take the same stance as Cummins in that they are not recommended in normal operation, but if the available fuel is not up to spec or for the current temp then they can be used and even have AC Delco additives in the bullitin.
03-06-04-017L: Information On Diesel Fuel Additives – 2018 And Prior GM Chevrolet And GMC Light Duty...
Dec-17-2017 09:46 AM
Dec-17-2017 09:30 AM
mowermech wrote:
Yes, I know what "cide" means. I deal with herbicides, biocides, and other types of "cides" on a regular basis. Farmers are not the only people in the world who know about such thing, y'know!
From my reading, I have come to understand one thing about algae growth in diesel fuel: No water in the fuel, no algae will grow.
The algae grows only at the water/fuel interface.
I check my water/fuel separator and fuel filter frequently. No water, no "red algae", so no problem, no need for a biocide.
Again, find and READ the MSDS for the products you buy. It can be very enlightening!
Dec-17-2017 09:16 AM
Dec-17-2017 09:15 AM
path1 wrote:
You did notice... I'm using the word percentage and not miles, right?
I'll stick with doing all my maintenance 10 percent early. Oil sent in to be checked about once a year for me.
path1 wrote:
(side note) being you see oil testing results...seeing any results in the new oil spec yet? Spec "K" or whatever they are naming it.
Dec-17-2017 09:00 AM
Dec-17-2017 08:31 AM
mowermech wrote:
For those who wish to use additives, do a google search for "home-brew diesel fuel additive". Since there are only three components in the most pop0ular additive (according to the MSDS), it is quite easy to mix your own for less than $10 per gallon!
Look up the MSDS for your favorite additive. Find out exactly what is in the stuff. I looked up a highly recommended biocide recently. I won't have a bottle of that stuff on the property! It is worse than Roundup weed killer!
Dec-17-2017 08:17 AM
Dec-17-2017 07:36 AM
Dec-17-2017 06:47 AM
