โOct-22-2016 02:46 PM
โNov-17-2016 04:09 AM
โNov-16-2016 06:36 PM
Steve_in_29 wrote:
WHERE??? are you going to stick that in even the largest TC?
It also burns through .49 gal per hour at rated capacity.
โOct-31-2016 04:12 PM
โOct-31-2016 09:26 AM
Firmy wrote:
Well guys, I have a desiel truck. Two 20 lbs tanks of propane in an outside storage box built in the side of the camper for fridge 120v or Propane. stove/oven propane only. hot water propane only. and heat propane only. I don't have solar at the moment but thinking about it one day. The propane can get used up pretty quick if running the heat as well as other units. I have a Honda 2000 in a storage compartment area that it fits in without any other room. At some point I would like to put a small AC on the roof ( that's another question in itself, what small AC would run off a Honda 2000) so I would like to run the gen here and there for micro, toaster, AC and charge the batteries. I have room on the back camper outside possibly on the upper wall other side of the ladder where I was thinking about mounting a portable gas unit. Wanted a more permanent solution so it was always there if needed. I have in the past put a small gas can on a back rack hocked into the 2" receiver. Bungee it to the rack other side of the exhaust pipe. Worked fine but just one more thing to worry about when leaving on a trip.
โOct-30-2016 02:20 PM
โOct-28-2016 07:11 PM
user113 wrote:
Of course, you could always upgrade to a diesel generator, that way you'll have a 35 gal tank for generator fuel right under your truck.
Diesel RV Generator
โOct-28-2016 12:05 PM
โOct-28-2016 08:46 AM
โOct-28-2016 06:14 AM
Diesel RV Generator
โOct-27-2016 07:32 PM
โOct-27-2016 12:18 PM
Steve_in_29 wrote:Good point Steve.stevenal wrote:
I converted my home generator for use with propane, and it works well. Plugs into a quick connect fitting on the tank with a short piece of hose. Why not do the same for a portable camping generator? No fuel storage issues for those already using propane.
Still going to have to figure out a way to bring a spare LP tank, as a genset can really suck one dry fast.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โOct-27-2016 11:09 AM
โOct-27-2016 10:47 AM
โOct-27-2016 07:58 AM
