GM Silverada Beats F250 In Frame Twist Test
FishOnOne
Enjoy....
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
41 REPLIES 41
spoon059
Gotcha Rick, I thought you were serious. I agree its absurd. Anytime there is a test that touts one as the best, or competition as worse then the brand loyalists come out. I am just trying to provide a moment of relief from commercials that prove nothing through random "tests".
2015 Ram CTD
2015 Jayco 29QBS
rickgu
Hey I thought we were talking about frame flex, I just wanted to join in on the conversation. I think you guys are taking this way too serious.
2003 1500HD 6.0 L 3.73
2007 Jayco Jayflight 27.5 BHS
spoon059
Really Rick... a picture of an OBVIOUSLY overloaded Superduty is the best you have? Did I write or imply in any way that the Ford F250 was capable of carrying an infinite amount of weight?
If I remember correctly, my argument was that the F250's frame is satisfactory for its rated and intended weights and for its expected service life. I'm sure I can find a photo of some hillbilly that overloaded a GM frame (they are better right, less flex) and snapped it in half. I'm sure I could find a Volvo longhaul with a damaged frame too. Just cause their are idiots out there that overload a truck doesn't mean that it doesn't work to its engineered specs...
2015 Ram CTD
2015 Jayco 29QBS
MM49
If you have a vehicle with high frame flex, it will drive its self on uneven roads when loaded heavy. The frames will flex and affect the steering geometry. Any engineer should know this.
MM49
Bedlam
Moderator
Moderator
When will people realize that marketing will manipulate photos or videos for their purpose? If we wanted to show frame failure, there are plenty of examples from any manufacturer.
http://www.youtube.com/watch?v=WBNll0bTYZo
You have to decide whether this is typical or an anomaly. I am not trying to pick on any brand and can provide examples from any of them.
rickgu
spoon059
ktosv wrote:
Spoon, your understanding of fatigue is flawed .
Therefore, your statement about engineers allowing for flex to prevent failure (from fatigue) is flawed. They may allow for this flex, but they better be accounting for the fatigue life based on the deflection and cycling.
You sound much more knowledgeable that I am, so I defer to you. My understanding of the exact science behind it is flawed, but the end result appears to be the same. These frames were designed to handle the stress and still have a long service life.
This "test" doesn't make GM's frames any better than Ford... it simply means that it doesn't twist as much.
2015 Ram CTD
2015 Jayco 29QBS
Mvander
Ummmmm. I prefer Mike Rowe.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
MARK_VANDERBENT
Fords frame bending has to do with all those 6.4 radiator failures. The link a few pages back really was interesting. GM really beefed up those frames in 2011 and they did a good job.
ktosv
spoon059 wrote:
Basically the argument is that steel needs to have some flex. Without flex it bends. When it bends it becomes fatigued. When it has fatigue, it is more likely to fail. To prevent it from failing, engineers allow for some flex.
Spoon, your understanding of fatigue is flawed . By definition fatigue is the failure of a material due to alternating or cyclical loading. This loading will cause some level of deflection, which would be referred to as flex if it was less than the yield strength and permanent deformation if it is greater than the yield strength. When it flexes back and forth it is actually causing fatigue regardless of the amount of deflection. The material will eventually fail at a load/stress much lower than the materials ultimate strength. Therefore, your statement about engineers allowing for flex to prevent failure (from fatigue) is flawed. They may allow for this flex, but they better be accounting for the fatigue life based on the deflection and cycling.
Your link that you posted even included this information: "and fatigue is the behavior of a material when subjected to cyclically applied stress, which can result in a crack and failure.
โ€œFatigue is what kills truck frames โ€” not tensile strength or yield strength,โ€ he said. โ€œFatigue is when you bend something until it breaks. Every material has an elastic zone. If I bend the material and don't exceed the yield strength, it will come back. If I get past the yield strength, I've strained it. It doesn't go back to the original shape.โ€
Kevin and my...
Wife and six kids
2017 Suburban (5.3L/6A/3.08)
6x12 Enclosed Utility
Sold...2011 Express 3500 (6.0L/6A/3.42)
Sold...2010 Passport Ultra Lite 2910
spoon059
Dadoffourgirls wrote:
Spoon never likes to have Facts interfere with good Internet stories. So for all the non-engineers, just believe Spoon and anything he says (which is usually negative about GM). For Engineers, just let the marketing department teach Spoon.
Really pops? You just mad cause I've blown up your nonsense theories before? Its not personal, just stating the truth. This test means nothing to the world of RV'ers. This is a stupid propaganda test. I know where your loyalties lie, so I understand your deep seated passion to defend GM at all costs.
I gave a solid reference to support my theory. You, on the other hand, are slinging mud and trying to obfuscate the issues. All the name calling in the world does nothing to support your argument, nor disprove mine.
Show me all the Ford Superdutys that experienced frame failure due to the "weak frame" shown by this "test". Until you have proof that Ford's frame is indeed weak and that this test adequately proves it... I stand by my statements. Just because you don't like reality does not, in fact, change reality.
2015 Ram CTD
2015 Jayco 29QBS
hone_eagle
Didn't GM post the same test about a year or 2 ago?
Older trucks , Same results.
Dead horse beating or what?
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
Fordlover
mich800 wrote:
Maybe there is merit to that test. But it doesn't apply to how I use my truck. I do have one question. Is this a problem that needs to be solved? I.E. do contractors or others that use their truck in the field park them in a situation where one or two wheels are off the ground and need to unload? It seems if you are in that precarious of a position it would not be a safe place to load/unload.
But if you do unload with a tire 3 feet off the ground, you better be driving the chevy or you'll be in trouble. Then again the tailgate would be about 6 feet off the ground so unloading would be awesome to watch.
I'll take flex over breakage any day, but this is all moot IMHO since I'm not aware of a single frame breakage issue on any truck.
Flexing buildings are being researched for robustness against earthquakes, interesting to me, though very different from a vehicle frame.clicky
2016 Skyline Layton Javelin 285BH
2018 F-250 Lariat Crew 6.2 Gas 4x4 FX4 4.30 Gear
2007 Infiniti G35 Sport 6 speed daily driver
Retired 2002 Ford Explorer 4.6 V8 4x4
Sold 2007 Crossroads Sunset Trail ST19CK
Turtle_n_Peeps
Now this is frame twist I can get into! :B
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
