Grey water pipe and fitting
Chris79
Where is the best place on the web to search for grey water piping. Have a small leak in mine. Iโ€™m not even sure what to search for lol. I see itโ€™s ABS pipe and fittings but am not finding what Iโ€™m looking for, straight nipples and fittings. Nipples have factory made bell end on them. Thanks in advance.
8 REPLIES 8
NanciL
The gray with "bell mouths" is probably just electrical conduit. You can get it at any Lowes, and they have all the fittings
jack L
Jack & Nanci
time2roll
ABS at any hardware or plumbing supply. Probably 1.5" pipe. Post a pic to identify the fitting.
beemerphile1
It should all be standard off the shelf ABS parts.
If ABS is unavailable you can use PVC with a rubber coupler between the ABS and PVC.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
myredracer
Try a local plumbing wholesaler. Or do an online search for the part you want and find an online source. Some RV dealers stock a selection of ABS fittings. Should be easy.
MSchu
In Texas they all sell PVC pipe, but I was in California and the Home Depot there stocked mostly ABS pipe. You could probably find what you need on Home Depot or Lowes websites and get free shipping if you buy enough.
I'm not sure about the nipples with bell ends, you should be able to use standard fittings and then just cut your own nipples out of a section of pipe
prichardson
Your local plumbing supply or hardware store is probably the best source for what you need.
NanciL
Have you tried Lowes or Home Depot plumbing section ?
Jack L
Jack & Nanci
ScottG
Just a note, double posting of the same thing is against the rules here.
Good luck.
