GVWR
bristles
I'm looking at a 1 ton drw. What is the gross weight on the door sticker ? The new chevy's are at 13025lbs. Because I don't know the weight of the empty truck yet, can anyone tell me if an Arctic fox 990 will stay under the limit
33 REPLIES 33
Kayteg1
GVWR is administrative number and depends at what bracket the state taxes go up.
You see it jumping from 11,400 to 14,000 to 15,000 lb.
That is where most states change taxes and/or licensing requirements.
For years I drove F450 with 15k rating and had it at or above 20k more than once. Tires were good for 22k.
Don't plan your set base on taxing clerks charts, but get real axle ratings and go from there.
brholt
You should be fine with any of the newer trucks especially if it is gas. My gas 2013 Ford CC Lariat DRW has a GVWR of 14,000 and the yellow sticker list the maximum payload as 6,220 lbs.
jimh406
You'll be safe with a 990 with room to spare on a newer drw truck.
jmtandem
You will need to go get more accurate numbers off the exact truck you want but here is a generalization. The 990 will weigh around 3600 pounds dry with the mandatory package and then add water, battery and propane and some options and about 500 pounds of stuff. That would be around 4600 or more pounds. The empty truck will weigh approximately 7500-7700 pounds. I usually calculate the Torklift tie downs and the removed tailgate to be about a wash. Don't forget to add the weight of people, fuel, dogs, bicycles, kayaks, and if you tow a trailer.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
