Happijac maintanance
billyray50
Winterized our new to us TC a few days ago due to a couple of unusual 16 degree lows nights arriving here in North Dallas. Decided to do some maintenance of the TCs Happijacs since it has sat in Truck camper warehouse for 2 years. Oiled the crank sockets with some 3:1 oil, waxed inner tubes, and removed the front motors and greased the gears with white lithium grease. Went to remove rear jack motors and noticed the inside mounting screw behind each rear jack seemed like it did not have enough clearance to back off completely before hitting back of camper? Has anyone done these rears lately and do you have to remove jacks from camper brackets to be able to grease motors?
11 REPLIES 11
Jack_Hart
This is one of the most helpful threads I've ever seen. Using this information I managed to pull two failing jacks apart and bring them back to like new operating condition. Thanks very much.
KKELLER14K
Well you are all welcome. Education is what I try and give only because I have been through the fails. You learned some valuable, time saving, headache, OH ****! what do I do now??.. moments. And of course it will always fail when you need it to work yesterday or it gets stuck on the truck...Seriously take a day and tear them down and do yourself the favor. When the jack lags behind or the clutch starts rattling midway...you can tell a fail is coming. And yes a lot of those factory drains are too short and poorly placed...It's not really hard to do but well worth the cost and effort.
billyray50
Will do the long flexible rain spouts. Already on my xmas list. Factory spouts to short. I will be putting bags on the heads from now on . Good idea. Thanks.
d3500ram
KK14K- Thanks for that write-up... on my summer to-do list too!
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
KKELLER14K
You can create a wet environment just pull out your garden hose...lol.... the point being... you want to check to make sure your gutters are not draining onto the top of the motors. If they are you may have to get the longerdrain extensions I had to do that to mine. Be sure to get the long flexible ones not the hard plastic ones they break off too easy... and if you're in a wet environment for long periods just throw some 1 gallon Ziploc bags over the top of them just to help Safeguard getting any moisture intrusion it's worth the Peace of Mind and of course if you're storing it outside for long periods of time you definitely want to cover them.
billyray50
AidenJ wrote:
I thought the same thing, but there was enough room to remove the bolt.A pain in the butt getting it back in.:B
That's what I was concerned about. Will probably removes rear jacks from bracket. Thanks.
billyray50
KKELLER14K wrote:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22881036.cfm
You might want to give this a look....although you have done good so far.. you should also learn how to take the jack completely apart and lube the jack screw...Also cover your motors with a plastic bag and make sure the gutters are not spilling water directly on the motors themselves.. Looks like you will just have to unbolt the jack itself to get the motor off but you will have to do that anyway to get to the jack screw.
Thanks for reminding me on your thread. I read this here back in 2012. My previous 2012 Adventurer 86 FB the jacks inner tubes were completely rusted all the way up. Did not see this when taking delivery when dealer was raising TC up to load on truck in the pouring rain that day. Talked with Brad at Adventurer and He coordinated with Happijac to send 4 new generation nickel plated jacks and new motors under warranty which I installed. Great thread . Will keep for future maintenance.
sonuvabug
... snipped ... You might want to give this a look....although you have done good so far.. you should also learn how to take the jack completely apart and lube the jack screw...Also cover your motors with a plastic bag and make sure the gutters are not spilling water directly on the motors themselves..
You did a fantastic job with your HappiJac lubrication tutorial. Thanks so much ... it's now on my "summerizing" list for this coming season.
When you suggest covering your motors, are you suggesting just during the lube procedure or all of the time when not rolling?
2007 Adventurer 90fws Truck Camper
2001 FORD F250 SuperCab; 8' box; 4x4, 7.3l diesel, rear Sumo Springs
AidenJ
2014 Dodge Ram 3500 CC, CTD, SRW
2010 NORTHERN-LITE 10-2 SPECIAL EDITION)
Libby, 2 yr Boxer/Hound mix learning to travel
KKELLER14K
pastorbillv
I just looked at mine (on the rear) and I would have to remove the whole Happijac from the camper to work on it.
Good luck!
Bill
2004 Bigfoot 29G (Love the garage!)
2017 Northern-Lite 10'2" SE on F-350 (CC, Dually, 4WD, Boss)
