May-20-2021 01:25 PM
May-22-2021 11:19 AM
May-22-2021 08:13 AM
JoeChiOhki wrote:
The logic I can see and its not just unique to Happijacks is the rear jacks in most cases have the tubes anchored the full length down the wall of the camper, allowing the camper to restrain the side to side movement of the jack tube. The fronts are only anchored on at a very small section of the tube turning them into giant fulcrums.
When you tip the nose higher the rear jacks are restrained by the camper itself and don't begin to flex to the side as the weight application changes.
When you go the opposite direction, the front legs have nothing to prevent them from flexing or twisting toward the rear, apply enough downward dog pressure and the jacks will either buckle or the anchor points will fail, because you've been applying a twisting forcing to that limited anchor area with a fulcrum. (Think of how using a cheater bar on a socket wrench amplifies the force at the nut or bolt, you're doing the same with your front jacks).
May-21-2021 01:37 PM
CB
Channel 17Redneck Express
May-21-2021 07:46 AM
Fishbreath wrote:
If you feel that comments to your questions are not accurately answered, I would suggest contacting the manufacture for answers.
Good luck and welcome to the Forum
May-21-2021 07:21 AM
May-21-2021 07:15 AM
mt-ed wrote:AISURFFISH wrote:mt-ed wrote:
"Never raise the back of the camper higher than the front".
Why?
If you seriously have to ask this question then you do not need to be owning a truck camper...
Hmmmm...your response clearly indicates that you do not know the answer to my question either, and camouflage your ignorance with such a useless response!
"If" you are truely so wise and "all" knowing why are you here if all you're going to do is insult those of us that are trying to learn?
Your response added absolutely NOTHING to the advancement of truck camping!
May-21-2021 06:38 AM
Why?
May-21-2021 06:30 AM
Why?
May-21-2021 06:24 AM
Why?
May-21-2021 03:50 AM
Why?
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
May-20-2021 07:02 PM
May-20-2021 06:05 PM
May-20-2021 05:38 PM
May-20-2021 01:33 PM
