have experience with a Shadow Cruiser TC, (1993) ?
HighwayPilot
My question is will this model 950 fit on a 2004 F250 with a 6'7" bed. Dealer says no, But it would still rest on the tailgate. I figure I have 8 1/2 feet of bed with tailgate down.
Thanks for any help given
Virgil, May & Fred (the yellow Lab) ๐Ÿ™‚
6 REPLIES 6
walkeraw
I have the 1995 model of this camper. It will fit and should not interfere with the holding tanks/dump valve area. You may need to ensure adequate cab height clearance (2x4 boards would add height and cantilever support if tailgate is not used). Don't think the tailgate would be much cause for concern, though. Just make sure you have good tiedown support. My TC sticker indicates 1868 lb. fully loaded (40lb propane and 17gal fresh water).
jaycocreek
The guy that bought my old Lance Squire hauled it off in just about the same set-up(pickup) with the tailgate down holding the rear but the Lance was like 8'6"..He uses it today as he did a couple years ago without issue.
My advice would be to get some tailgate supports..I have looked hard at them to haul my Yamaha Rhino in my 8 foot bed with the tailgate supporting some of the weight loading.There not to expensive like $60 or so.
https://www.dgmtailgatesupport.com/product-category/tailgate-support/
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
AnEv942
No experience but also check the truck cab height clearance.
As to the tailgate, its not designed as a load bearing 'bed extension'.
Really doesn't offer much resistance to weight. Weakest would be the cable mount points.
Only reason might work is I assume camper doesn't weigh that much.
But the camper itself may yield if not fully supported?
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
WNYBob
Yea, that was not safe, he didn't even have his talegate down!
joerg68
Nomad III
Nomad III
Like this?
http://forums.trailerlife.com/index.cfm/fuseaction/thread/tid/29406953/gotomsg/29535361.cfm#29535361
In all seriousness... watch the rear axle weight.
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
Kayteg1
I think the major question is not if you can make it fit, but how strong is your tailgate.
25 yo camper will likely have weak floor, so it might take some reinforcing all together.
