Height of AF 811 while loaded on an F350?
Xpd77
I just purchased an Arctic Fox 811 but won't be able to pick it up for a month or so. I will be putting it on my 2012 F350 SRW and I'm wondering if it is going to fit in my barn or not. Does anyone have this set up and knows what the overall height is going to be? My barn door is about 11 feet 5 inches tall.
2012 F350 SRW Diesel. 2014 Arctic Fox 811. Torklift tiedowns, Fast Guns, and Stable Loads.
11 REPLIES 11
Xpd77
Thanks for all the replies guys. It doesn't look like mine will be fitting in my barn unless I offload it onto a dolly and then pull the dolly inside. I guess it will be sitting outside this winter at least.
Bedlam
Moderator
Moderator
I'm over 12' tall with my AF811 and F250. The new nose on the AF is taller, but overall height has not changed.
kerry4951
Most of the AF TCs are all about the same height. My 1140 on my truck is 12'4" tall to the top of the AC. I cant get my unit under a standard 12' high garage door. My truck sits high in the rear so that does make a difference. My guess is that you will be very close. Make sure you have a spotter when you first try it.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
Xpd77
It is a 2014 with the new nose style. I'm pretty sure it is only the nose that is 4 inches taller and not the overall height of the roof.
Mich_F
According to the web site the new ones are 9'4" including AC.
AF811
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
n7bsn
New production? I recall seeing that 2014 models are taller (4 inches?) then old models.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Xpd77
Its 58in to the top of my bed rail. If I add 90in and subtract 3in for squatting that puts me right at 12 feet. Hmmmm, maybe if I air down my tires I can squeak it in my other barn which is right under 12 feet. Not the barn I want to put it in though.
Dirtpig
Hey XPD, I went out and measured just my 811 camper (off truck). You could measure up 78" from top of your truck box, add about 12" if you have the AC installed. You could subtract about 3" to account for truck "squat" once the camper is on. This would be an approximate measurement of course. Hope that helps you.
2015 Nash 25C bumper pull /w 300watts solar my install
My Truck & RV youtube channel
2005 F-350 Diesel 4x4 CC SB SRW
2001 Honda XR400: many mods
12ft Lund WC boat & 9.9 Yamaha 4 stroke on custom loader.
WyoTraveler
Xpd77 wrote:
Mine is a 4x4 with 20in wheels. I'm just trying to get an approximate height.
My F250 4x4 also has 20 inch wheels. The TC would push down on the bed a little so it wouldn't be quite that high. Just a guess.
Xpd77
WyoTraveler
Lots of variables. I would call the dealer and ask them the the height and add it to your bed height. Guess a lot would depend if you had a 4 by 2 or a 4 by 4 F350. I do see the AF 811 is 9' 4" with A/C. My F250 4 by 4 bed is right at 38". That would put you at approx 12' 6".
