I have the Sunlite Apache 6.9 camper, same as the Sunlite, except it is an entry model.
The manual I received is for all Sunlite campers, operation of the heater, stove, refrig are covered. I also have the brochure for Sunlite, if you want I can copy it into a PDF and e-mail it to you.
my camper fits on a Dakota with helper springs. A battery is needed unless you have a larger battery bank in the truck. I wouldn't run it on the truck battery alone, you may have a wee bit of trouble starting the engine after a long stay. My refrig is 3-way, propane, 12vdc (not recommended - HIGH current draw), and 117vac. Everything else in the camper is set up for 12vdc. The outlets are 117vac and if you are camping away from power, a generator would be a good idea.
For cold weather camping, I have a small electric heater to help the propane heater. If you have "shore" power, it will save on propane.
[img]
[/img]
