You don’t need a wdh or the hassle of additional considerations with that truck, camper and trailer even if you truly will have a 600lb tongue weight. You got newer better wheels that have great capacity tires. The 7200lbs for the wheels IS the limiting factor if you choose to follow it. OE rims are hard to find ratings for but it’s pretty universal they’re thought to be or are rated for 35-3600lbs. And they are very durable at those weights and a bit more. (Think about the OE mfgs liability with their wheels on the millions of HD pickups that get abused and misused regularly. If they were failing every time or any time someone overloaded them a bit, just the negative publicity alone, not even getting to liability cost, would be a death sentence for an OEM. Hence they’re all over designed. Proof? None actual, besides, watching, driving, repairing or being responsible for 100s of HD pickups over the years used in construction by anyone from folks like me to hundreds or thousands of employees who can barely sleep their name (sometimes literally) but are goin to get the job done that day…
Real world personal TC example. Short bed Dodge 2500 on OE 17” alloys and later OE 20” alloys. Real world rear axle weights from the 7200lb range to approaching 8klbs depending on the trailer. 20-30k miles of loaded driving including the Alaska Highway at the upper and of the range and all over AK at the lower end (far worse highways (frost heaves) than most anywhere in the L48) and never an issue with tires or wheels.
Another thing worth considering, idk if you own the trailer you describe or just planning for the smallest trailer that will haul that buggy. But a slightly longer tandem axle basic utility or car hauler trailer will provide you far more latitude in optimizing tongue weight and also stability/durability of the trailer. Trailers are easy to sell/purchase and not a huge difference in total expense if you’re smart and patient.
Added bonus, with any TC, storage space is at a premium. Especially if you’re packing gear, parts and fuel for a hot rod SxS as you are. A bit bigger, lot better, trailer will afford you a bunch of space for not only tongue weight adjustment but also more storage options.
Worth thinking about.
