โJun-23-2015 08:16 AM
โJul-09-2015 12:49 PM
Turtle n Peeps wrote:
You can keep on saying it, but it's still not correct.
You might have heard of Sunoco? They make a few gallons of gasoline / day.
โJul-08-2015 01:05 PM
โJul-08-2015 03:32 AM
FelixTC wrote:
Cccougar,
So many misconceptions. Google octane ratings and fine out what the experts say. Using a higher octane than what your truck calls for is like taking two one-a-days instead of one. It does absolutely no good. Regardless if you're towing or not. Anyone who says different is taking a placebo and letting their imagination get the best of them. You're not going to get better gas mileage or performance.
โJul-07-2015 07:10 PM
Higher octane fuels have slightly less energy (Btu), BUT, have a slower burn rate which allows for higher compression through mechanical means, aka compression ratio, or artificial means, aka spark advance, and will generate more power from slightly less energy.
SUNOCO wrote:You might have heard of Sunoco? They make a few gallons of gasoline / day. :W I would think they know what they talk about and they say the same thing I'm saying: Octane and burn rate are mutually exclusive. One has nothing to do with the other. Link
You might be surprised to learn that some of the highest octane fuels may also be some of the fastest burning fuels!
โJul-07-2015 10:11 AM
โJul-07-2015 09:27 AM
I'm confused? :h You were talking about BTU's and then in your last sentence you talk about burn rate. Those are two different things entirely.
โJul-06-2015 06:53 PM
philh wrote:Turtle n Peeps wrote:
Technically, saying that premium has less BTU's is like saying I just took a leak in the ocean and now it's higher. Is it true? Ya, but.........:R.
More like adding to a 55gal drum ๐ I used to have the energy numbers, but they are long gone ๐
Point being, it's the burn rate of premium that's an advantage to engines built for higher octane fuel, and to a lesser extent engines tuned to run it.
โJul-06-2015 04:45 PM
โJul-06-2015 09:11 AM
โJul-06-2015 06:42 AM
marcsbigfoot20b27 wrote:philh wrote:
{sigh}
Higher octane fuel has LESS Btu's of energy per gallon. What it does have is a better controlled burn rate under higher pressures.
Run the mfg recommended fuel.
I run premium in my 5.7L only because my engine has been retuned to use the higher octane fuel.
Another issue with premium, today's "gasoline" deteriorates over time. If you get a station that doesn't sell enough premium fuel, the quality can actually be lower than regular or mid grade. Many stations blend regular and premium to get to mid grade... but not all. Finally, you can run into stations falsely selling regular as premium. I can tell within a mile of leaving a station if I truly pumped good quality premium. Because my engine is after market tuned for it, spark advance gets pulled very quickly with lower grade fuel.
Did I mention, run the mfg recommended fuel?
Oh please cite where higher octane gasoline has less BTUs .......and I don't mean something trivial like 200 BTUs out of ~115,000 per gallon avg.
โJul-05-2015 10:21 PM
philh wrote:
{sigh}
โJul-05-2015 06:13 PM
โJul-05-2015 06:09 PM
โJul-05-2015 05:25 PM
