bradg wrote:
Turtle n Peeps,
The weight from the scale for the Yukon w/o Trailer is 2820 Fr Axle & 2940 Rear Axle with a gross weight of 5760.
With Trailer, it was 2400 Fr Axle, 4400 Rear Axle & 6080 Trailer Axle (both trailer axles on one scale section) for a total of 13080.
Something is screwy? Unless you had a ton of weight in the back of that SUV when weighed it something is wrong IMHO. I'll see if I can do some checking at get back to you.
Ok, I did some checking and those numbers are screwy.
According to this site, your Yuk should be 52/48 weight bias to the front. Or 51/49 if you have an XL.
Unless the numbers change significantly from 2010 to 2013 and those numbers you posted are actual scale numbers and not door numbers something is very strange? I just don't know what to tell you?
BTW, that is super good weight bias for a factory vehicle. Almost a 50/50 car is a great thing to have.
Sorry I couldn't be more help. (Or any help at all, lol)
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
