Holy Creaking and Popping Batman!
Faribo
So a little background here.....I purchased a TT with a Reese dual cam weight distribution/sway control system with the round bars. The dealer installed everything and all the wheel well measurements came out perfect so I thought "all is good"....well jump ahead 3 months and I noticed now that the WDH spring bars have absolutely no tension on them no matter what link I use. I start to investigate and find out that the dealer never installed the large locking washers to keep the head from tilting!!! I could probably fix this myself (after I chewed out the dealer and made them send me the parts) however since this is my first TT I wanted to make sure it was done correctly so I made an appt at a very reputable dealer here locally and had them fix the problem.
Now to my issue....when the hitch was first installed it didn't have any of the popping and creaking I've heard about but now after it was installed correctly it is creaking and popping like mad. I do not have the spring bars greased in the hitch head (will be doing that tomorrow) but is this much creaking and popping normal? I get quite the looks as I drive around the block. 🙂 My spring bars are level with the trailer and I am using the 5th link on the chains.
Would love your thoughts and let me know if more info is needed to give some advice. 🙂 Thanks!
10 REPLIES 10
_tiredTeacher
I named my Equalizer hitch "Moana." :B
Teach
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
Linedog
I had a lot of noise when I got my hitch. First stop was home to grease the ball and bars. After adjusting the head for the third time, it tows great and makes very little noise.
Poptarts and gravy, It's what's for dinner.
beemerphile1
I like the noise because it proves the system is working as it should.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
SDcampowneroper
Try angling your hitch head downward another notch or two. The WD bars hould have 6-8 links of chain when under load which allows more swing movement in turns.
Jerallen
The bar ends can be lubed with vaseline only per Reese. This may quiet it down a little but the noise is the friction of the bars resisting movement- this is the premise behind their design.
I suspect the head movement was in the initial tow and you never really had any true sway or much WD this would explain the lack of noise.
I have learned to live with my dual cam noise and yes, it creaks, groans, squeals a little and pops like mad. BUT- does a great job.
Verne
Welcome to the sounds of summer . . .
-Verne, Brenda and
Latté, a Welsh Corgi
Carson City, Nevada
2010 Tundra 5.7L
2010 Jayco JayflightG-2 23FB
eu2000i Honda generator and Companion
Equalizer WD System
EldIr
If you ever sit in a campground and listen to people coming and going with their TT's, you'll hear all sorts of creaks, groans and pops. Even when lubed.
'01 Burb 2500 4x4 496/4.10 (3.73 effective w/ new tires)
'94 Jayco 300BH
downtheroad
Don't grease the cam ends...only the hitch ends and the hitch ball.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Faribo
BurbMan wrote:
Faribo wrote:
I do not have the spring bars greased in the hitch head....
That's your problem in a nutshell....also grease the hitch ball where it goes into the coupler.
that's what Ii was hoping for!! Just thought I'd ask to see if otherwise it was normal. Thanks.
BurbMan
