โFeb-17-2018 06:12 PM
โFeb-21-2018 08:01 AM
โFeb-21-2018 05:16 AM
wnjj wrote:GeoBoy wrote:
When a manufacturer states the maximum payload it doesnโt take into consideration that the load is going to be 12โ to 13โ tall. On my truck the maximum payload is 5,813 lbs., but the maximum truck camper payload is listed at 4,913 lbs..
That difference is usually due to the camper rating assuming 150lbs in each seating position where payload does not. Does your truck have 6 seats?
โFeb-20-2018 07:16 PM
JIMNLIN wrote:I think the sentence in your response after (4) is taken out of context. I believe that sentence is from 19.05 Weight scales of the B.C. act. It is explaining how a vehicles weight is calculated by the peace officer. It is in a section explaining the procedure of weighing a vehicle and such. It is not explaining how much weight you can carry.
Sure its how a vehicles gross weight is calculated. Add up the trucks individual 5600 fawr and 9375 rawr = 14975 lbs for its gross weight or as BC uses calls it a GVWR.
And add the trailers gross axle weight numbers GAWR (three 7k axle) = 21000 lbs which is the trailer GVWR. Added together gives the combination a 35975 lb gross combined weight.
(4) The gross weight of any vehicle or combination of vehicles shall be the sum of the individual gross axle weights of all the axles of the vehicle or combination of vehicles.
Any ways if I was going to tow a trailer in BC I would contact their size and weight folks at a troop post and ask them how they determine if a vehicle is overloaded. Asking someone at a 1-800 number in the main office at the state or provincial capital most of the times lead to nowhere or they give you a phone number to a troop post near you.
โFeb-20-2018 06:35 PM
โFeb-20-2018 03:37 PM
This from a commercial haulers website concerning how their truck gvwr is determined. Found this on a haulers website thread which was poking fun at rv website myth about the truck makers gvwr determining how much load a truck can legally/safely carry. These guys and gals are scaled every day so they should know what BC says.
BC Motor Vehicle Act Regulations
Weight scales: (1) thru (3) snipped for length
Your 3500 DRW won't have any legal or safety issue carrying weight in the bed right up to its 9xxx lbs rawr in BC
โFeb-20-2018 12:20 PM
โFeb-20-2018 11:58 AM
โFeb-20-2018 11:48 AM
โFeb-20-2018 11:33 AM
hedge wrote:
I don't know what you mean, they get the numbers from the manufacturer. 2nd point in the FAQ
This recreational not commercial.
โFeb-20-2018 11:32 AM
JIMNLIN wrote:Area13 wrote:
OP, sorry you have to worry about the Canadian weight police. I think the 2015 GMC 3500 hd dually you are looking at would be a great match for the Cascade.
โFeb-20-2018 11:19 AM
hedge wrote:
It's not a myth, below is a link directly from the BC government website.
https://www2.gov.bc.ca/gov/content/transportation/driving-and-cycling/traveller-information/seasonal...
about 1/2 way down the page:
Motor Vehicle Act Regulations in B.C. prohibit the operation of vehicles that are unsafe or improperly loaded and exceed either the Gross Axle Rating (GAWR) or the Gross Vehicle Weight Rating (GVWR). These regulations apply to recreational towing, utility towing and boat towing.
BC GVWR FAQ
I still think most people would be ok as it still has to 'look' overloaded before they will do anything and there just don't seem to be that many cases of it happening.
If it did though it could be a real hassle.
โFeb-20-2018 11:13 AM
BC GVWR FAQ
โFeb-20-2018 08:25 AM
โFeb-20-2018 07:50 AM
BC GVWR FAQ
โFeb-20-2018 07:13 AM
