โMay-01-2021 08:10 AM
โMay-13-2021 08:24 AM
JRscooby wrote:
Part of my test kit is a 2-prong turn-signal flasher with jumper wires attached. Hook it in place of fuse, will work as auto reset circuit breaker. Then you can follow the wires with non-contact amp meter. When you pass the short the needle will stop jumping.
โMay-13-2021 07:00 AM
cockroach wrote:
I know this is basically an LED question but I thought it worth mentioning that an incandescent light does not care whether it is AC or DC. It will work on either.
โMay-13-2021 06:05 AM
โMay-03-2021 01:11 PM
โMay-03-2021 10:58 AM
bucky wrote:
The OP stated that he had unplugged the awning lights and the fuse still blew.
"I inspected and disconnected the awning lights, checked the cable that goes inside, checked the switch, all good, but still it blows the fuse."
โMay-03-2021 03:39 AM
โMay-02-2021 07:38 PM
โMay-02-2021 01:36 PM
โMay-01-2021 07:13 PM
โMay-01-2021 06:15 PM
MitchF150 wrote:
Sounds like you have a short in the awning wiring? I assume it does this whether you are on just battery or 120v?
And it's just the awning light that blows the fuse either way?
Turn on your inside lights on and no problem?
Turn on your awning light and it blows the fuse?
Or a combo of both?
Not sure how you test that, but you gotta somehow take the internal wiring out of the equation with some test wires to see if it's the fixture or the wiring?
Good luck! Mitch
โMay-01-2021 06:05 PM
โMay-01-2021 05:52 PM
2oldman wrote:alexey75 wrote:and this 'wall' is a 12v socket?
From the awning into the wall.
โMay-01-2021 05:25 PM
โMay-01-2021 04:01 PM
