Jun-05-2014 07:08 PM
Jun-06-2014 06:48 AM
shawnzy wrote:
I had the battery run out from putting the slide out 3 times other day
Jun-06-2014 04:52 AM
Jun-06-2014 04:51 AM
Bull Rider wrote:
I bought a hand held meter, and cut the probes off of the ends of the test leads and then wired it into the 12 volt feed to the AM/FM radio. Velcroed the meter to the inside of the cabinet door next to the radio. Open the door, flip the meter to DC, and I get a readout to two decimal places.
Total cost was about ten bucks. Works for me.
Jun-06-2014 04:40 AM
Jun-06-2014 01:24 AM
Jun-06-2014 01:23 AM
Jun-05-2014 09:46 PM
Jun-05-2014 09:44 PM
Eyetattoo wrote:Just to the back of the plug. As long as no load is on the plug it basically measures voltage at the fuse panel. Close enough for what I need.
Did you run a line to your battery bank or just tie into the 12volt plug behind the plate?
Jun-05-2014 09:30 PM
Jun-05-2014 09:17 PM
smkettner wrote:Did you run a line to your battery bank or just tie into the 12volt plug behind the plate?
Jun-05-2014 09:16 PM
Jun-05-2014 08:37 PM
gemsworld wrote:
I use this one:
INNOVA 3721 Battery and Charging System Monitor
Jun-05-2014 08:26 PM
Jun-05-2014 08:10 PM
Jun-05-2014 08:06 PM
4aSong wrote:
This is the unit that we have installed.
Universal 12v Digital VoltMeter
