How high is too high?
clarkster
Looking for a more powerful tow vehicle for my trailer.
F-150 with a 5.0 V8 lags on grades uphill.
A Ram CTD 5.9 piques my interest somewhat.
Where I roam, there is no ULSD available so one that requires that is out......hence an older (2006-7) Ram with the Cummins.
What would be considered high mileage on a 5.9?
I am seeing 160K.....170K and on up for a 2007.
Slim pickings under 100K miles.
2006 Dodge 2500 4x4 Laramie crew CTD
2017 Jayco Flight SLX Baja package
5 REPLIES 5
Grit_dog
Navigator
Navigator
For the engine, you can reasonably expect double the mileage you're looking at with a good chance the inj pump and turbo will last that long too. Rest of the truck is the same as any other high mile pickup. Totally dependent on the care, maintenance and a little luck, lol.
But as said above, if you're in Mehico, just buy a newer one of you want and delete it.
Delete is removing all the emissions systems that require the ulsd.
You're a perfect candidate for it. Cost a couple thousand for everything to do it.
Redwoodcamper
My last three Dodge/Cummins have had over a million miles combined. One with over 400k. If they have been taken care of then the engine will last a very, very long time. The truck around the engine will have some problems after 200k. Steering components, tranny issues, interior, etc will be more of an issue.
2011 ram 3500. Cummins 68rfe. EFI live. 276k miles and climbing.
2017 keystone bullet 204
clarkster
Kennedycamper wrote:
If you don't have auto emissions checks you can delete a 07.5 to 12 dodge and run regular diesel.
I am not sure what you mean?...
Can you be more explicit......thank you
1stgenfarmboy
A high milage cummins would be somthing above 300k for me.
150k is not what I consider high.
I have owned 4 cummins trucks all but one with over 250k and never a problem.
my current truck is a 93 with 163k that is low miles for this truck.
1993 Dodge W350 Cummins with all the goodies
2014 Ram 1500 Laramie Longhorn 2wd 395hp
2017 Forest River Surveyor 243 RBS
2001 Super Sherpa & 2012 DL650A go along also
Kennedycamper
