Nov-22-2016 11:09 AM
Nov-24-2016 04:20 AM
Bumpyroad wrote:Bucky Badger wrote:
I don't have a kit, but all I do is unhook the tank side of the pump and hook the siphon hose there instead and put the hose in a jug of antifreeze
a $17 kit will make life easier. expecially if your pump is at all difficult to reach.
unfortunately I could not put the valve on the input side of the pump without major surgery so I put it on the output side and pump AF in with a boat bilge pump.
bumpy
Nov-24-2016 04:17 AM
Nov-24-2016 03:40 AM
sac89 wrote:I Have done this in the past, It should be fine.. Just flush good and sanitize as advised per other members..
Ok, total rookie mistake, and I should have thought about it prior to doing it. But how much did I mess up???
I asked a fellow RV'er friend of mine about winterizing my TT with anti freeze. He said, "piece of cake", just pour the antifreeze into your water tank and turn on the faucets till they run pink.
So dumb-ass me goes and pours 5 gallons of antifreeze into my freshwater tank. After my first gallon I thought to myself, "self, this is a really stupid idea. I am contaminating my freshwater tank" So with the damage being done, after the first gallon was in, I pressed on and put in the other 4 gallons, thinking what's done is done. I ran the lines until they poured pink.
My question is, just how screwed am I? Will I be able to flush 5 gallons or antifreeze out of my freshwater tank in the spring? Will I be able to drink out of my camper again? Do I fess up to my dealer/mechanic that I did this?
Thoughts? Suggestions?? Bullets for my skull???
...after I told my friend that I did this, he turns and says that he simply blows air thru his lines to get the water out...nice.
Nov-24-2016 02:54 AM
Nov-23-2016 03:15 PM
Sprink-Fitter wrote:Bucky Badger wrote:Sprink-Fitter wrote:dodge guy wrote:
RV antifreeze is not unsafe and is biodegradable. In the spring just flush the fresh water tank a couple of times. And then sanitize it as you would every spring.
In the future just pour 3 or 4 gallons into a 5 gallon bucket drop the pick up tube in and siphon out of that.
Where do you get the pickup tube from?
It's usually just a piece of clear tubing 1/2" ID
https://www.amazon.com/Camco-36543-Pump-Converter-Winterizing/dp/B0006JJ588
I'm wondering where the pickup tube goes? If you are sucking that into your water tubing where is the pickup tube?
The pump would suck water from the tank.
Nov-23-2016 12:40 PM
Nov-23-2016 09:33 AM
Nov-23-2016 08:21 AM
PackerBacker wrote:Steve 83406 wrote:
My fresh water tank in my Prowler 24C is just below the sofa. The drain fitting is on the side and as close to the bottom as could be made. Even after draining, there is about 1/2" of water in the tank, so I have had to add the pink antifreeze to it to prevent the residual water from freezing. I suspect many tanks are like mine, and you've actually helped yourself in the long run...
It doesn't much matter if it freezes. I don't think I have ever had one that drained to nothing. As long as it is 'empty' for the most-part, there is lots of room for freezing water to expand.
Nov-23-2016 07:10 AM
Nov-23-2016 06:34 AM
that will taste worse than the AF would after a few rinses. if for sanitization, a few hours or overnight will do.
bumpy
Nov-23-2016 06:28 AM
Nov-23-2016 05:59 AM
Nov-23-2016 04:46 AM
