Bob is correct. What you can tow is directly tied to your GCVW rating of the truck. My Dodge 2500 had an 8800 pound GVW, all to do with the wimpy little stock tires, and the GCVW rating was 19,300 pounds. It would have been higher if I had the 4.10's and an auto trans. The truck weighs around 7000 pounds wet. The difference between these two numbers is the maximum of what I can carry and/or tow. I know I have exceeded this maximum weight on occasion.
I remember reading on the Turbo Diesel Registry some years ago about a towing weight spitting match. Some of the Dodge 3500 guys have towed for a short distance 32000 pounds, or upwards, but the clear winner was a guy with 5th wheel, a farmer who towed a 3 axle, duals, (that's 12 tires) with an abundance of hay bales about 2 miles down a country road with a mind boggling 53,000 pounds, gross. The chatter stopped dead in it's track with that one. Nothing broke, no harm, no foul, but he was the clear winner, and I don't think he got up enough speed to have to use any brakes, as they would be hopelessly outgunned by his momentum. I think he put a picture up at the time I thought, "Gee, what a tiny little model truck you have there."
jefe
