how to mount rear view camera
wiredgeorge
I am a newb to RVs and trailers in general and my backup skills are minimal at best. I would also like to see behind me going down the road. I think a wired backup camera system would likely be the right answer. The trailer is a Sunnybrook Harmony 21FBS. There are marker lamps and the two turn signals, of course. The wall on the back of the trailer is the bathroom and I am not keen to penetrate that wall for pulling the wiring. Anyone have a similar trailer type and situation that can give me advice on how to mount a camera and run the wiring? I am looking at a wired Rear View Safety system that has been discussed a lot on this forum. Tips please! TIA wg
wiredgeorge Mico TX
2006 F350 2002 Keystone Cougar 278EFS
2006 GL1800 Roadsmith trike
7 REPLIES 7
myredracer
They sell backup cameras and just don't seem to consider how people will actually mount them on the back of a trailer. In our case, there was no way I could get the wiring from anywhere on the rear wall inside without drilling a hole through the fiberglass so I made a bracket thingy from some scrap steel that sits on the bumper. I can MIG weld so this isn't for everyone. I did this last year and haven't replaced the tie-wraps with permanent screws or bolts/nuts yet.
The Garmin camera comes with a cable that is maybe 2-3' (?) long and the connector is not watertight so I used some heat shrink tubing over it. Ran the cable from below the frame up inside a kitchen cabinet at the rear of the TT and then through the ceiling space to the front overhead cabinet above the bed where I put the transmitter.
The exact mounting location isn't critical (left/right & elevation) as you can tilt/pan the image on the GPS.
justafordguy
I installed a Furrion FOS48TAPK-BL Wireless High-Speed RV Observation System. I power the camera from the center top running light on the back of my trailer. The system works awesome.
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
ROBERTSUNRUS
๐Ÿ™‚ Hi, I made a mounting bracket for my camera and stuck it on the back of my trailer with automotive two sided tape.
๐Ÿ™‚ Bob ๐Ÿ™‚
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
wiredgeorge
I don't have a motorhome as mentioned and can't always rely on someone to spot me backing up. thanks for the help guys. Will figure it out. I will look behind one of the marker lights (I guess that is the same as "triple lights").
wiredgeorge Mico TX
Second_Chance
Our fifth wheel came pre-wired (Furrion mount) but the power was always on to the camera. Not wanting the camera to fail prematurely, I switched the power lead to a wire for the running lights at the top of the rear of the trailer. Now all I have to do is turn on the running lights on the truck and the camera comes on.
That being said, I find these wide-angle rear view cameras of minimal help backing. My wife with a two-way radio is much more useful. On the other hand, since I have a full-time rear view monitor and not just a backup camera, it's some extra assurance knowing when it's safe to pull back over after passing a semi on a mountain pass. In the long run, the best thing to do is get some orange cones, go to a big empty lot, and practice, practice, practice.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Cobra21
I have one inside of a back window that works well.
WNYBob
I would look behind the triple lights, there may be a conduit to the vent, which may have a constant 12 vdc.
