โDec-12-2014 07:33 PM
โDec-13-2014 05:27 PM
MargaretB wrote:3oaks wrote:
I don't see any discrepancies just because the dealer doesn't have what you are looking for on their lot. Dealer's inventory usually consist of what they think their customers may want and will sell quickly. If buying new, order exactly the truck you want with the options you want, not what someone else thinks you may want. That is what I do.
The discrepancies lie between what the sticker says and how the math works out. I know the mfrs tend toward the conservative side to cover their bacon, but on one that we looked at, there was a 700# difference between the sticker and the website, and the sticker and the math.
โDec-13-2014 05:04 PM
rexlion wrote:
MargaretB, if you think you want to buy a high-payload F150, be sure to find and test drive it before deciding for certain. They will ride differently than the one you rode in. To get the higher payload, they have to use different springs and such; this will change the ride.
โDec-13-2014 04:08 PM
โDec-13-2014 03:20 PM
โDec-13-2014 02:20 PM
cekkk wrote:
MitchF150's stickers indicates passenger tires and 35 psi. How does that work with an HD claim? Certainly that would be an important factor in Ford rating the vehicle's carrying capacity, no? My truck's sticker wants 65 psi up front, 60 rear, for its booties.
โDec-13-2014 02:16 PM
โDec-13-2014 01:49 PM
โDec-13-2014 01:20 PM
โDec-13-2014 12:01 PM
โDec-13-2014 10:54 AM
โDec-13-2014 10:53 AM
โDec-13-2014 10:49 AM
carringb wrote:MargaretB wrote:
The dealer adds a little this and a little that - maybe a tow mirror and a bed-liner. They increase the curb weight, which reduces the difference between curb weight and GVWR, and supposedly reduces the mathematical computation of available payload.
But in each case, the differences between the sticker and the mathematical computation (GVWR minus curb weight) was huge - many hundreds of pounds, much more than the weight of the items the dealer/s may have added over time.
And if I understand this process correctly, if the sticker is the holy grail, then no one should ever add anything to the vehicle after it leaves the assembly line, because doing so will render the sticker incorrect.
Do I have that right?
The yellow sticker accounts for all factory options. The discrepancy is the published and advertised weights which all carry the "up to" disclaimer. Nobody says you can't add items to a truck. You just have to do your own math in relation to the yellow TREAD sticker. BTW - aftermarket upitters, like companies that install racks and bins, or RV builders, to have to revise the sticker to reflect the final "as-built" configuration.
And i'm not sure where this "Holy Grail" idea from. It's simply an easy way to identify the capacity of each truck as it leaves the factory. It's not legally binding to the dealer or the buyer. It's simply another tool to help you buy the vehicle you need.
If you really want to find out the capacities of new Ford trucks without looking at trucks on the lot, you can use this workbook to evaluate the affect to your desired options and configurations:
https://www.fleet.ford.com/truckbbas/topics/2014/14_TruckPayload_SB.pdf
โDec-13-2014 10:31 AM
MargaretB wrote:camp-n-family wrote:But the math is compelling. If you subtract the curb weight from the GVWR, you should get the payload, no? Math doesn't lie. So why is the sticker so much less? Where does the mfr. come up with these figures?
You are correct in that you get payload by subtracting the curb weight from GVWR. The discrepancies are due to the configurations and options. Most ads and salesmen will use the best case scenarios which sound best. A base model, regular cab, 2x4 can have 3k payload. A crew cab, Lariat, 4x4 will add a lot to the vehicle's curb weight, which subtracts directly from the payload.
You need to go by the sticker, they are legally mandated and are accurate. Keep in mind that sticker number also gets reduced by dealer added options like bed liners, side steps etc. The 2k+ payloads are rare to find on a dealer lot. You'll likely need to special order the tow and HD payload package. If you're going to go there you might as well get a 3/4 ton of the lot for less $.
I'm definitely not a mathematician, but I'm wondering about some things here.
The mfr. sets the payload, based on what he puts on the truck as it rolls down the line. That's the sticker.
โDec-13-2014 10:10 AM
