โSep-26-2019 05:15 PM
โJan-17-2020 04:51 AM
โJan-16-2020 09:45 PM
โJan-16-2020 08:30 PM
ticki2 wrote:
Just a thought looking at you picture . I made some inserts like that to fit into the trailer hitch to mount cut down semi mud flaps for trailering . Really kept the trailer clean .
โJan-16-2020 02:40 PM
โJan-16-2020 02:06 PM
โJan-16-2020 02:04 PM
โOct-05-2019 07:30 AM
โOct-04-2019 06:16 PM
โOct-04-2019 06:08 PM
โOct-04-2019 05:42 PM
burningman wrote:
My hitch isnโt open at the ends so I just welded some 2โ square tube to the ends of it, and I use 1 1/4โ tube for the inserts.
I didnโt see the need or even want a plate on the end. I just drilled a hole and put an eye bolt in the ends. I did a belly bar for the front.
Iโm with you, if you have a welder and a chop saw and maybe another tool or two, thereโs zero reason to shell out what people shell out for extremely simple bits of metal.
โOct-04-2019 02:11 PM
ajriding wrote:
If you weld all day then you know why the Torklift mounts cost $700. They are well made and actually they make them to order often in order they don't have hundreds of different configurations collecting dust on the shelf (different brand trucks, different years all need different designs).
I am no pro welder, but came close to making my own, but opted instead to use the Torklifts. I have no regrets, though I typically do like to DIY for most everything.
The "cuts" or slots could be just the continuous cutting byproduct, but my theory is that this is a built-in weak link. Given enough tension this part might bend and let go before other components break. I could be wrong, and some TCs might have very weak toe-down points on the camper which would break first. You never want the truck frame to be the weak link.
Building these yourself often results in over-built, very strong braces, which could bend or damage the truck frame. I think most drivers would prefer the TC just fall off rather than anything on the truck become damaged.
Your Fastguns were a good choice.
A key thing to keep in mind is that the tie-downs (chains or Fastguns) oppose each other front to rear, where one chain pulls the TC forward and the other pulls the TC backwards. This balance of fore/aft tension helps keep TC in place and prevents it from sliding forward when braking or rearward when accelerating. The tie-downs should make and angle, not just route straight up and down.
Yes, the front of the truck bed will stop forward movement, but the bed is not necessarily made to hold a TC in place like that, better for the chains to hold it.
โOct-04-2019 01:51 PM
โSep-29-2019 07:46 AM
โSep-29-2019 07:22 AM
GAR2 wrote:
Well...... Iโll try again ๐
https://m.imgur.com/gallery/EfyCLHN
โSep-28-2019 11:14 PM
