If Casita ever made an Off Road trailer this would be it.
RobertRyan
This is from a Company called Elite Caravans and their tiny 14ft "Dirty Harry" watch the video below. Yes typical Extreme Northern Australia Jungle landscape.
"Dirt Harry" Off Road Mini Caravan
14 REPLIES 14
RobertRyan
juanitahere wrote:
Two spares even! Looks like a great idea for that tough towing. Is that standard or an option?
Pretty common with a lot of Caravans here.
RobertRyan
69 Avion wrote:
Is it an anodized aluminum?
With a compact 14ft by 7ft 6in body, the Dirty Harry is equipped for some serious bush-bashing, with a 150mm dual beam, galvanised chassis, Cruisemaster independent coil suspension, DO35 hitch, galvanised sheet underfloor protection, two heavy-duty spare wheel carriers, and 16inch alloy wheels with Cooper Discovery mud tyres.
To make sure it can stand up to some Clint Eastwood-style punishment, the Dirty Harry also features โ€˜hail resistantโ€™ aluminium stucco cladding, plus checkerplate protection for the body as well as the two, 60 litre water tanks
Generally the Interiors on their larger vans about 35ft Overall, is somewhat "Scandinavian Chic". Interestingly No slideouts.Full Home Airconditiong system, not a normal RV one.Pop Up Bedroom TV, other TV's located elsewhere.
69_Avion
RobertRyan wrote:
cpaharley2008 wrote:
Nah, it is not fiberglass.
Fiberglass does not last long Off Road in a tropical climate. Colour impregnated metal.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
69_Avion
It looks like the ground clearance is good in the middle but the susupension on each side seems to hang down quite a bit. I'll bet that it still will perform very well. There are a few specialty trailer in the US that use that type of coil spring suspension and some of them use air bags instead of the coils.
juanitahere
RobertRyan
billb8801 wrote:
Too many seems to be,caulked
Not a problem with Off Road Caravans they pressure inside the Caravan
To keep water and dust out.
BillB800si
Too many seams to keep caulked....
Bill B. (S.E. Michigan)
2015 Dodge Ram Crew Cab 4x4 Hemi
2016 Rockwood Windjammer 3029W
Sunbird
Nissan doesn't sell the Patrol in the US. The Xterra and Pathfinders are built here. No diesels.
mockturtle
I like the interior. Basic is good.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
robsouth
Thank goodness for that!
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
RobertRyan
cpaharley2008
2009 Dodge Ram Hemi 4x4 11,300miles- lifetime warranty
2012 Toyota FJ-500 miles
2014 Escape 21' All Season trailer
RobertRyan
Inside shot basic but OK.
_DJ_1
Very impressive!!! Love the suspension. Would of liked a peek inside and a better look at that hitch. Obviously not conventional!!!
And you've stated before, these rigs come with LT tires!!! Should speak volumes for the anti LT crowd!!!
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
