Interesting article on brakes
agesilaus
Warped Rotors Myth
And how to extend their life: 4 Wheel mag. I'm sure some will not agree with it but it makes sense to my non-expert thoughts. It has nothing to do with 4WD by the way,
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
10 REPLIES 10
srt20
My wife gets build up all the time on her work car. I just take it out and beat on the brakes for a little bit and it always stops the shaking.
Me_Again
They have little 3M pads for drills that an auto parts store had me use to clean the rotors. They come in different cleaning grades.
https://www.amazon.com/3M-Scotch-Brite-07481-Aluminum-Conditioning/dp/B0002STR8Q/ref=pd_sbs_263_1?_e...
https://www.amazon.com/3M-Cleaning-Holder-Speed-Lok-Quick-Change/dp/B0019CLI1S/ref=pd_lpo_vtph_263_t...
Lynnmor
Roger10378 wrote:
I hadn't thought about it being the adhesives in the pad. I have had mine feel like the rotors were warped after a hard stop and then get better after a few normal stops so this makes total sense to me.
You will find that the drum brakes on trailers depend even more on those adhesives to be seasoned before the brakes are very effective. The brake manufactures spell out a "burnishing" routine for new brakes.
Roger10378
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
mosseater
very interesting article. Thanks for sharing.
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
theoldwizard1
I solved my "warped" rotor problem on my E150 by using ceramic pads and premium quality rotors.
BenK
Below are links to old threads on this topic...
BEDDING IN NEW FRICTION MATERIAL
Basically, it is getting the friction material binders to cure them and then not allow that 'out gassing' to condense on a single spot of the rotor
But, an even layer on the whole swept surface. Best braking or highest co-efficient of friction is when friction material brakes on friction material (properly bedded in)
In the below links, the best at that time, was an article by StopTech, but they removed that and replaced it with this one: StopTech: The "Warped" Brake Disc and Other Myths of the Braking System
Their index of tech articles:
http://www.stoptech.com/technical-support/technical-white-papers
This image from StopTech is what this topic is about:
Only takes a few thousandths of an inch to make a high spot that the brake pad will have higher co-efficient of friction and 'try' to stop a bit better/faster....and....that will be felt in the brake pedal to your foot. Many think that is a warped rotor
Do disagree with most folks (and experts) that there is no such thing as a warped rotor...I've measured many that were out of spec (warped)
Old threads on this that adds additional info
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/382340/gotomsg/382437.cfm#382437
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/412131/gotomsg/412248.cfm#412248
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/7658246/gotomsg/7665526.cfm#7665526
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21467853/gotomsg/21472800.cfm#21472800
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22703862/gotomsg/22704841.cfm#22704841
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/13110233/gotomsg/13152256.cfm#13152256
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22703862/gotomsg/22704841.cfm#22704841 Why don't like cryo rotors
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25902357/gotomsg/25923795.cfm#25923795 Ford F150 brake issue thread
[url]
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
fj12ryder
Yeah, I've read stuff like that a couple years ago. It would be easy enough to check. If you feel like you have a warped rotor, just check the runout. Not a big deal.
Howard and Peggy
"Don't Panic"
agesilaus
gbopp wrote:
It is interestkng, thanks for posting.
Maybe it's worth trying?
Doesn't seem like their suggestions could be damaging anyway.
Superbumper
gbopp
