โAug-30-2018 07:33 AM
โAug-30-2018 09:24 PM
โAug-30-2018 08:39 PM
โAug-30-2018 12:49 PM
SnowSTi wrote:
I recently bought a new travel trailer and a used truck to use as the tow vehicle. When I bought the truck I was told it had a 3.73 rear diff... anyhow after some investigation it has the 3.42. That drops the tow capacity down to 6700lbs from 7700lbs which is cutting it close for my rig ( Here are the details )
2008 GMC Sierra 1500 Crew Cab Shortbed
5.3L / 4L60e / 3.42 diff / 2WD / G80 locker
Trailer package
Heavy Duty rear suspension
Upgraded Transcooler to 24,000 GVWR (Hayden 678)
Jayco 267BHS
5690Lbs dry / 6200Lbs loaded
Equalizer WDH
The truck tows the trailer well in 3rd gear on the highway at 2400 - 2500rpm. Never downshifts unless it's a very steep hill. Acceleration is slow but acceptable. Transmission temps hover between 70C - 80C while towing during the summer.
I've done some smaller 2-3 hour trips already with the rig and it will cruise along quite happily on the highway. However I've got a longer 4000km trip later this year which has me thinking a bit.
Would going to a 4.10 from the 3.42 be worthwhile? It would move my cruise rpm up to 3000 in 3rd which seems unnecessarily high, but I assume would make accelerating a bit better.
It would cost me about $1000 to get the rear diff swapped, plus I would then need to get a programmer to correct the speed/transmission shift points.
The rig in question
โAug-30-2018 11:03 AM
SnowSTi wrote:
Looks like 4.88 would probably be more appropriate for my rig. OD would work well for cruising, 3rd would be a good hill gear.
Ok sounds like this is a no brainer especially since the truck is only 2WD so it's not too pricey.
I'll see about getting it done and will report back with the results.
โAug-30-2018 10:26 AM
โAug-30-2018 09:18 AM
time2roll wrote:
Is 2300 rpm enough to hold OD? 4.88 puts you at 2461... about same as now.
Hard to know as I have not driven it. If you are solid at 2300 then the 4.56 is fine.
โAug-30-2018 09:08 AM
โAug-30-2018 09:01 AM
โAug-30-2018 08:42 AM
Groover wrote:
With a 4 speed transmission you could end up in a situation where with the new rear end you will get 2000rpm in 4th and 2800rpm in 3rd at highway speeds and neither one is really comfortable. You may want to evaluate that before making a decision. "Never downshifts unless it's a very steep hill. Acceleration is slow but acceptable." You may already be in your sweet spot.
โAug-30-2018 08:40 AM
SnowSTi wrote:
Yeah I would need to go to a 4.56 to make use of OD I think. Looks like I'd be at roughly 2300rpm at 65mph using 4.56 gears. That probably makes more sense than the 4.10s.
This truck is used exclusively as a tow vehicle so I don't care how it performs when it isn't towing.
โAug-30-2018 08:37 AM
โAug-30-2018 08:21 AM
โAug-30-2018 08:08 AM
โAug-30-2018 08:03 AM
โAug-30-2018 07:54 AM
