โOct-12-2016 04:29 AM
โOct-15-2016 05:48 AM
RoyB wrote:
The Cherokee of course is getting into the bigger frames and all and should be able to tow more then the TJs etc...
โOct-15-2016 05:21 AM
โOct-14-2016 07:18 AM
sch911 wrote:
It is potentially doable.... (Jeep Engineer here)
Need more info.
What year is the JGC?
How long is the TT?
โOct-13-2016 12:15 AM
โOct-12-2016 05:26 PM
โOct-12-2016 02:49 PM
sch911 wrote:DGOYLER wrote:
We are looking into lighter TT's. Probably 26'-28' in the wet range of 4500-5500lbs
our Jeep is a 2014 JGC Overland 4x2 3.7L V6 with a tow rating of 6,200lbs
Actually it's a 3.6L Pentastar engine (we don't make a 3.7L anymore).
My TT ratings for this generation JGC are:
26Ft. maximum length.
6000# maximum weight.
A WDH with true (non friction) integrated sway control (such as the Hensley).
We towed much larger trailers during the development of this vehicle under very difficult temperature and grade conditions. I am certain you'll have no issues if you stay with those recommendations (despite what the naysayers have been saying).
โOct-12-2016 02:11 PM
โOct-12-2016 01:32 PM
Chuck_thehammer wrote:
example. my 04 Ram 1500 3.7L v6..2 wheel drive. with a manual transmission. had a towing of 3,300 pounds.. same engines as yours.
my trailer was 3,000 pounds empty. that engine worked Real Hard on the smallest of hills. WV,V,Tenn. 4,500 rpms and 45 mph... on freeways. with 3:55 gears.
can it do it "YES" but will it last?????????
โOct-12-2016 01:30 PM
beemerphile1 wrote:
Can it do it? Technically yes, but it won't be a pleasant experience. The small tow vehicle and lack of power will be very noticeable.
Go somewhere like etrailer and search for weight distribution hitches. In brief, they take weight from the rear axle and apply it to the front axle. The Equal-i-zer brand is popular.
Keep in mind that passengers and gear in the tow vehicle should be subtracted from the tow rating.
โOct-12-2016 01:17 PM
ChooChooMan74 wrote:dodge guy wrote:
The new 3.7L (Pentastar) is different than the old 3.7L.
The new 3.7L has plenty of power, but I would reserve it only for a PuP or a small TT. the neighbor down the street has a Durango with the 3.7L and tows a 22ft Hybrid and hasn`t complained about power, but he stays within 5 hours of home!
For the kind of weight your considering I would go with the V-8.
You are correct about the Pentastar being a totally different engine, but it is 3.6l compared to the 3.7. I would consider a Pentastar in a Ram 1500 short wheel base single cab if I ever needed a work truck.
โOct-12-2016 12:55 PM
โOct-12-2016 11:51 AM
โOct-12-2016 11:49 AM
