โDec-02-2016 02:42 PM
โDec-03-2016 11:14 AM
Sam Spade wrote:jake2250 wrote:
So it starts blowing cold air then ends by cooling everything off again..
If the air coming out really IS colder than ambient, then you have TERRIBLE insulation on your ducts and that needs to be fixed.
The fan runs a bit extra before and after to get all of the heat out of the heat exchanger and into the living area. It may FEEL cold but hopefully really isn't. Do an actual measurement to be sure.
โDec-03-2016 10:46 AM
โDec-03-2016 06:36 AM
โDec-03-2016 01:15 AM
โDec-02-2016 11:45 PM
โDec-02-2016 11:10 PM
โDec-02-2016 10:45 PM
โDec-02-2016 07:56 PM
โDec-02-2016 07:47 PM
trail-explorer wrote:jake2250 wrote:
Yes,, thats my issue, If I could reduce the amount of fan run on after the flame goes out it would retain the heat. Instead it feel like it is blowing off the heat generated.
It's blowing the generated heat (from the heat exchanger/flame chamber) into the RV... so I'm not sure what's bad about that.
It's a safety function to cool off the heat exchanger before shutting down the fan. I'm sure it's probably a safety requirement of the UL.
Home gas furnaces operate the same way.
โDec-02-2016 07:44 PM
โDec-02-2016 07:19 PM
โDec-02-2016 07:12 PM
RavensFan24 wrote:
Mine works the same way. My wish is that the thermostat would show the ACTUAL temperature in addition to the set temperature. When the heat runs, I feel like it gets super hot (well over how it was set) and then it cools off to what seems like well below how it was set. It makes me wonder on occasion if the propane is low or out, though I've noticed with the heat running more now that I'm in MD that the system won't kick on at all (fan and furnace or even just fan) if there is no propane.
โDec-02-2016 05:54 PM
