โSep-29-2022 12:58 PM
โSep-29-2022 09:45 PM
โSep-29-2022 07:35 PM
โSep-29-2022 07:17 PM
โSep-29-2022 07:14 PM
wanderingbob wrote:
Hitch up , pull up on blocks , work on the two axles that are off the ground , repeat for next set of axles .
โSep-29-2022 07:12 PM
MFL wrote:
No need to lift a bunch on frame. You only need to lift axle an inch, with a bottle jack, or floor jack.
I have a 2x4 piece of oak, about 8"s long, with a da-do in center, that just cups a U-bolt. This works great at home, using a bottle jack under it.
I also use my Trailer-Aid plus, which will lift front or rear tire high enough.
Using some boards cut and stacked will work too, best if on solid surface.
Hooking to vehicle is a good choice, adding stability!
Jerry
โSep-29-2022 04:42 PM
โSep-29-2022 04:41 PM
โSep-29-2022 04:08 PM
โSep-29-2022 03:52 PM
klutchdust wrote:
There was a post about this recently that was rather amusing. it drifted off to the point of questioning what the poster knew about floor jacks themselves. Look it up.
โSep-29-2022 03:34 PM
โSep-29-2022 03:33 PM
โSep-29-2022 02:36 PM
โSep-29-2022 01:32 PM
