โJan-07-2018 01:28 PM
โJan-09-2018 10:30 AM
Lynnmor wrote:
I guess the road service guys are disposable? They can play in traffic for all we care? :R
โJan-09-2018 10:24 AM
โJan-09-2018 09:01 AM
โJan-09-2018 08:56 AM
โJan-09-2018 07:35 AM
Lynnmor wrote:3oaks wrote:MarkTwain wrote:I would have the tire changed and on my way long before they got there. I found out long ago, self service is the best service. ๐
When I get a flat on my trailer, I call Good Sam Emergency Road side Service, open a cool drink, open up my news paper and relax:):)
That is as long as I am still able. :@
I agree with that. You also run the risk of the service guy jacking it up improperly causing damage. Even some of the wonderful PA inspection stations want to jack towards the center of the axle.
โJan-09-2018 07:28 AM
WayneAt63044 wrote:
I use a bottle jack positioned as mentioned above on the axle of interest. Beware that your lug nuts holding the spare may be a different size than those on the axles.
โJan-09-2018 06:39 AM
โJan-08-2018 02:10 PM
โJan-08-2018 01:08 PM
โJan-08-2018 12:22 PM
โJan-08-2018 11:34 AM
rbpru wrote:
During our walk through I asked the technician where to set the jack. He said on the frame. The axle tube might bend or deform.
I have had two flats on my TT, both were nail like punctures. Having the proper cribbing wood blocks for the jack and having practiced before hand was the difference between a twenty minute delay and waiting for road service to find you on some back road.
As already mentioned, some folk jack on the center shackle but the tech said he told folk to use the frame, because it was the least complicated for most folks.
We now have a Tire-Aid but it too has drawbacks. On the sandlot I call a yard, I place it on a 2x8 board to keep if from being pushed into the ground. Also, some TTs have wider spacing between the wheels. I do not know how well it would work with a triple axle TT either.
I can say it is really handy when you want to adjust the brakes. Just lift one wheel and adjust the other.
Another thing to note is, just because you torqued your lug nuts to the specified ft./lbs. Does not mean they will be the same at your next stop. I find mine need to be tweaked twice before they all maintained the recommended torque poundage.
Good Luck
โJan-08-2018 10:33 AM
โJan-08-2018 10:22 AM
โJan-08-2018 10:17 AM
