Jayco roof / owner failure
beeryboats
Hi all,
We just traded our '06 Jayco Eagle for a fifth wheel. All was well, got a great trade in value, and then we got the call. The roof was rotten all the way around. This was our first camper so I take some of the blame, but I've now read that a certain range of Jayco's had roof issues. I could see no rips, tears, or discolorations on the inside. Yet the roof was so soft in spots you could not walk on top. We took a pretty good hit on the trade, but I learned an expensive lesson. Get up there and crawl around and check that goop around every seam. Or hired someone to do it for you.
18 REPLIES 18
Jayco254
2006 and 2007 Jayco Jay Feathers I know had a bad habit of the a/c's not being fastened properly at the factory and the tpo material on the roof would wick the water all over and cause serious damage. I know on my '07 it cost Jayco a complete new roof, front cap, total right side and a complete floor down too the frame, plus the towing back to the factory. This is the first Eagle though that I have heard of this happening too.
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
spadoctor
Its true some Jayco, KZ and others had a problem with rigs built 2005 to 2007. The supplier of the roofing (TPO) manufactured it with the felt too wide. The material was to not have felt on the sides where it wrapped over and behind the gutters. I had the roof go and one wall delam on my KZ Durango (2007) and it was replaced at no cost to me in 2011. All depends on the dealer/factory relationship. Factory admitted they made a mistake in caulking bottom od gutter for a cleaner look. The TPO manufacturer paid 60% and factory ate the rest. It happens....all depends how its dealt with. As such we bought another KZ rig.
colliehauler
Pat & Karen wrote:
colliehauler wrote:
Pat & Karen wrote:
Been there done that. Paid $4000 to have the roof replaced. No obvious damage to the rubber membrane. Insurance won't cover it because to obvious cause found. My repair guy thought it was a manufacture defect but Jayco wouldn't cover it because it was out of warranty. Extended warranty excludes roofs. They even had another similar Jayco come in with the exact same problem. What a bummer you had to "find" it when you were trading it in. Congrats on the new trailer. Enjoy it!!!! Pat
A lot of Jayco's used TPO roof with a felt back that would wick water and rot out the roof. I'm not sure there is a lot you can do to prevent this.
Exactly what happened. My repair guy used a different material that did not have the felt backing.
Jayco new this was a problem and did not fix a known issue. I would think the dealer could get Jayco to take care of it.
Lantley
CavemanCharlie wrote:
I think he meant "Stealer" as in "Dealer" . I too don't understand the OP post though. If he already traded it in it's the dealers after that. It's there problem and I hope they didn't try to make him pay. Good advice though on keeping the roof maintained. And, when buying a used unit it's the first thing you should check.
I would like to think the dealer would inspect the unit before the deal is done. However I'm sure there is lingo in the sales contract that allows the dealer time to discover concealed damage or questionable financial info. Lots of states have 72 hour clauses.
It sounds as though the OP did not know the rig was damaged and agrees he may have unknowingly misled the RV dealer.
19'Duramax w/hips, 2022 Alliance Paradigm 390MP >BD3,r,22" Blackstone
r,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,Prog.50A surge ,Hughes autoformer
Porta Bote 8.0 Nissan, Sailun S637
Pat___Karen
17 Ram 3500 SLT Big Horn CCLB CTD 6 speed auto
17 Grand Design Reflection 337RLS
63 DH Fire Fighter 33 years
63 DW 1st Grade Teacher 12 years
95 DD Equestrian 10 years
2005 Ddog
2013 Other Ddog
CavemanCharlie
BillB800si
Ozlander wrote:
Stealer should have done the inspection BEFORE the contract was signed. Afterwards it's his and he pays to fix it.
You've been took.
Stealer ??
Not sure what you mean by that word. Please explain.
Bill B. (S.E. Michigan)
2015 Dodge Ram Crew Cab 4x4 Hemi
2016 Rockwood Windjammer 3029W
Ozlander
You've been took.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
BillB800si
In May we traded in our 2007 Jayco Eagle 322FKS sight unseen, by the dealer. They gave us a trade in price and that was that. There maybe some fine print in the contract that allows renegotiating if there is "major" damage to the trailer upon final inspection????
And yes we inspected our roof frequently for cracks - cuts etc....That's the weak point- if the roof leaks you're looking at major repair work should the trailer rot- delaminate etc...
At least the OP was honest and faced up to the situation.
Good luck on the new purchase.
Bumpyroad
also on some KZs.
bumpy
colliehauler
Francesca_Knowl
The Dung Beetles wrote:
fordsooperdooty wrote:
The letters "RV" loosely translates to "really loses value if you don't maintain it".
I should think however that if the trade in was already transferred to the dealer then their isn't a damn thing the dealer can do about it..it now belongs to him!
I was actually wondering the same thing. If the ink was dry on the contract after it was discovered - it was a done deal. They are supposed to be the professionals (and should have ck'd it thoroughly prior to sealing the deal). If not.. it was or should have been THEIR HEADACHE.
I sure hope the O.P. is paying attention here...he sounds like an honest man trying to warn us of the hazards of "neglecting" one's roof. But what if he's just getting getting the after-the-deal Royal Runaround from the folks that he inked a contract on a new rig with?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Pat___Karen
2005 Ddog
2013 Other Ddog
The_Dung_Beetle
~ It's a fine line between hobby and mental illness ~ Dave Barry
Carl, Felicia, Eva & Pip (the fur kids)
