โDec-04-2018 06:11 AM
โDec-10-2018 12:44 PM
โDec-10-2018 11:45 AM
mich800 wrote:
Sounds like something within the starting circuit. You are on the right track. Batteries, cables, ground, starter any or a combination could lead to the slow cranking when cold.
โDec-10-2018 09:46 AM
Picinisco wrote:ppine wrote:
Air filter should not be a problem at all.
The first thin I would check after the battery and starter, would be glow plugs. Any diesel should start easily down to around 25 degrees.
Its a cummins engine so no glow plugs. It has an intake heater. Checked it and its clean and heats up fine.
Problem is slow turning when cold(ish)
โDec-10-2018 08:34 AM
โDec-10-2018 08:31 AM
โDec-10-2018 08:18 AM
Picinisco wrote:4x4ord wrote:
You shouldn't need much of a battery to start an engine when the temperature is in the 40s or 50s.
You would think so. When on the block heater it starts right up.
โDec-10-2018 08:14 AM
โDec-10-2018 07:10 AM
โDec-10-2018 07:02 AM
โDec-10-2018 03:59 AM
4x4ord wrote:
If your truck has two new batteries you're likely wasting your money changing them. Your better off spending the money on having a diesel mechanic troubleshoot your problem. There are many things it could be from air in fuel: bad injectors: starter: low compression.... possibly bad batteries or maybe battery connections or cables.....
โDec-10-2018 02:15 AM
โDec-09-2018 08:58 PM
โDec-09-2018 08:08 PM
deltabravo wrote:
Ditto on both of the above.
Does it crank over fast and just not start, or does it crank slower like the batteries have low voltage?
โDec-09-2018 06:33 PM
And there is your problem. K&N is the absolute worst air filter there is. Even lightly over oiling it will kill your grid heater in a hurry. Not to mention loss of fuel economy and allowing more dirt into the motor. Your just asking for problems. Take it out, go buy a quality paper filter, clean the grid heater and see what happens.
BTW, I would dump the K&N. They are notoriously bad on turbo diesels and may actually be the problem. The oil in them fouls the MAP sensor so I would get some sensor cleaner and spray said sensor down.
โDec-09-2018 07:49 AM
Picinisco wrote:zcookiemonstar wrote:
Do you only have this problem when boondocking? Are you disconnecting your camper from the truck? If not this could just be a case of you draining your truck batteries with the campers power usage. Does your truck start fine at home without plugging in the heater?
No
Yes
No
I have thrown away the K&N filter and gone back to a paper filter. I have pullet out the intake heater to clean it but it is spotless.
The person i bought the truck from last february had just replaced both batteries, both marked 11/17 so i did not suspect them however on further examiation i find that they are 650cca batteries so suspect that they are a little weak, when cold, at getting the engine spinning to 200rpm, so when i get the $350 plus to replace them I will.
