โMar-12-2015 07:36 AM
โMar-13-2015 09:34 AM
shasta24 wrote:If it's something you'd like to have, it doesn't sound silly at all! It would certainly break up the visual expanse of the table top.
I have the same size table as the one above, with the glued together pine boards. That looks like a good table. I thought about laying a 12 by 12 piece of tile in the middle, to act as a built in hot plate. I would trace it and router it out, and glue it in. Sound silly?
โMar-13-2015 06:52 AM
โMar-12-2015 02:24 PM
โMar-12-2015 01:50 PM
โMar-12-2015 01:49 PM
โMar-12-2015 01:44 PM
โMar-12-2015 10:23 AM
โMar-12-2015 08:20 AM
โMar-12-2015 08:19 AM
the bear II wrote:
Most RV manufacturers use 3/4" MDF with formica type material glued to the top.
I would glue strips of hardwood (oak, cherry or maple) together and then shape it to fit your needs.
Once I used a hollow door to make a table. Hollow doors have a honeycomb inside made out of hard cardboard. They are lightweight but strong. You can cut it to fit and then add a wood strip to finish off the cut end. Only drawback is the thickness of the door.
โMar-12-2015 08:11 AM
โMar-12-2015 08:00 AM
โMar-12-2015 07:51 AM
