Lance 855/855S Battery Compartment Safety Issues
Mike_Stanbro
The following is from a paper I sent to the President of Lance Camper on January 15th of 2014. I have received no response of any kind from Lance and now feel it is appropriate to post this to the various Camper forums so that the consumers of their products are informed of what I consider to be a serious safety issue with the Lance 855/855S camper.
I would like to preface this post by saying that I have never taken the time to bring a product safety issue to the attention of a manufacturer before. I do so now as I am genuinely concerned about this. I don't just point out problems, I also make detailed suggestions on how to fix them. I do not seek any form of compensation. I do want Lance to respond to my claims.
I openly acknowledge that I have used a couple of pictures posted by another contributor to this forum who goes by the user name "skipro3" and I reference his post with a hyperlink in the document that I sent to Lance and in this post. I use his pictures as I had already repaired my camper before I got fired up enough to document my concerns and take any pictures of my own.
Please note that I don't use a fictitious user name on this forum, or any forum, as I believe in transparency.
Following is the content of the paper I sent to Lance.
Introduction
I recently purchased a Lance 855S camper. Most everything about the camper is excellent except the layout of the battery compartment. There are a number of issues about the battery compartment that I feel are worth documenting and are the reason I took the time to write this paper. In this paper I use 855 and 855S interchangeably as the battery compartments appear to be the same for both products.
First, let me say that I am an electrical engineer and I know that in any system design as complex as an RV, tradeoffs have to be made. An RV is essentially a small house that travels down the road. It is a significant design challenge and I have some appreciation for the kinds of tradeoffs that have to be made to satisfy all of the product requirements. That said, safety can never be compromised and the ability to access and service high-maintenance components of the RV should be high on the prioritized list of requirements.
When I look at the 855S as a whole, I see a great product in terms of comfort, features, and build quality, all in a light-weight package. I also see the following limitations which are no doubt tradeoffs due to weight and size requirements: limited outside accessible storage, relatively small holding tanks, and 20-lb propane bottles instead of 30-lb bottles. Another apparent tradeoff is the battery compartment. It must be a tradeoff as it is only accessible from the inside and is stuffed with so much other equipment that it makes access to the batteries extremely difficult. In addition, the batteries are in the same small compartment as the AC-to-DC converter which poses a safety hazard. I can get along with the other tradeoffs but the layout of the battery compartment and poor access to the batteries is so bad I feel compelled to document it. I discuss my perception of the safety and maintenance issues in separate sections of this paper.
Safety
Placing the batteries in the same small compartment as an AC-to-DC converter that makes the following statement in its installation manual is reckless and a product liability issue:
โ€œUnit is NOT ignition protected. Do not mount in the LP gas or the battery compartment.โ€
I am not making this up, see the outlined text of the scanned page from the PD4000 Power Control Center installation manual shown in Figure 1.
Figure 1: Scanned image of PD4000 Power Control Center installation manual.
Yes, the batteries are in battery boxes that are vented to the outside and I assume your engineers felt that was sufficient to prevent an accumulation of hydrogen gas in the compartment. I, however, do not agree. Here are some things to consider:
  • Flooded-cell lead-acid batteries, the type installed by my dealer and most dealers, out-gas during bulk charging. Bulk charging will occur whenever the batteries have been significantly discharged.
  • The batteries are vented to the outside through openings that are forward facing such that when traveling down the road there is positive pressure into the vents. The positive pressure will force any hydrogen gas to backflow into the compartment it shares with the AC-to-DC converter. The battery boxes are poorly sealed clamshells which cannot prevent leakage when positive pressure is applied.
  • It appears that Lance leaves it to the dealer to install the batteries and battery cables. Because of the difficulty in getting the battery covers off/on and the limited space to route the cables, the dealers tend to do a terrible job and hack up the battery box covers creating gaping holes from which hydrogen gas can easily leak. Figures 2 and 3 below are photos of one dealerโ€™s hatchet job. Clearly, this is NOT SAFE.
Figure 2: Close up of gaping hole in one battery cover. Safe?
Figure 3: View showing battery boxes in the same compartment as AC-to-DC converter and forward facing vents.
For more details and more photos of this ownerโ€™s experience, refer to the following post on the RV.net forum:
Wiring issues with my 2012 Lance 855S
My dealer did an equally poor job but in different ways. The holes in the battery covers were not huge slots like those in the previous photos; instead, the holes were not quite big enough to accommodate the rubber grommets so they simply left the grommets off which resulted in a wide gap between the cable and the hole in the cover โ€“ more than enough for gas to leak from. In addition, the lugs on the battery cables were so poorly crimped that several of them literally fell off when I attempted to reconnect them. Furthermore, the cables were made from #2 AWG house wire which is very stiff and difficult to work with and the cables were about three feet too long. Needless to say I threw those cables overboard and built new ones from fine-strand #2 automotive cable, cut to length, with soldered-on lugs.
Even if the battery covers are not molested by the dealer, they are poorly sealed at the junction between the top and bottom portion of the clamshell. From the experience of the owner who wrote the forum post and from my own experience, the dealers are having a difficult time installing all the screws that hold the clamshells together due to the cramped quarters. In particular the screws on the far right side of the right-hand battery box are nearly impossible to get to. Try as I might, I was not able to get one of those two screws installed.
But then, you might think to yourself that hydrogen gas is lighter than air and will therefore travel up and out the top of the battery box through the vent tube and it doesnโ€™t matter that screws are missing and the clamshells donโ€™t seal well. Right? Maybe not . . . consider the following sequence of events which I submit are a typical usage scenario of a truck camper and will possibly results in an explosion or fire:
  • The camper has been taken off of the truck and lowered as low as possible to aid entry at the campsite.
  • In preparation for departure from the campsite, the camper is raised up and loaded onto the truck during which the jacks are run nearly to their upper limit. This imposes a large drain on the batteries and they will need to be recharged.
  • The camperโ€™s electrical cord is plugged into the truckโ€™s 12V electrical system.
  • The truck and camper travel down the road.
  • While traveling, positive pressure from the wind created by the truckโ€™s movement is hitting the forward-facing battery vents.
  • Also while traveling, the electrical system of the truck is charging the batteries.
  • Due to charging, hydrogen gas bubbles out of the battery and is pushed outward into the small battery compartment due to the positive pressure on the battery vents and the poorly sealed battery boxes.
  • The truck and camper arrive at their destination and the camper is plugged into AC shore power which energies the AC-to-DC converter which is specified as being โ€œNOT ignition protectedโ€.
  • Boom ... an explosion and/or fire occurs due to the highly flammable hydrogen gas that has built up in the battery compartment.
Unless I am way off in my reasoning, this is a significant product liability issue and needs to be taken very seriously. This is especially true when you consider how badly the battery covers are being molested by some dealers.
As I see it, there are several things that can be done to help mitigate this problem. Here are some of the things I have thought of.
  • Only install AGM type batteries as they are reported to out-gas much less during charging.
  • Pre-install the batteries and pre-route the cables at the factory to prevent the dealer from doing the kind of hatchet job shown in the photos.
  • Vent the batteries in such a way that the vents are exposed to only negative pressure (vacuum) when traveling. This would require that the vents be side or rear facing.
  • Move the AC-to-DC converter to another compartment.
AGM batteries pre-installed and pre-wired from the factory is likely the easiest solution. It is my understanding that AGM batteries have zero maintenance which would help with the issues I raise in the Maintenance section. It is also my understanding that AGM batteries out-gas much less during charging. I am not an expert on battery chemistry so will defer to others to verify the accuracy of those statements.
Maintenance
In addition to the new Lance camper, I currently own a boat and a 5th-wheel RV. In the past I have owned two other boats and one other RV. As such, I have a fair amount of experience with maintaining batteries in battery boxes. I have never experienced such limited battery access as in the 855 and I have never had such difficulty in taking the cover off of a battery box. There is simply too much stuff inside the battery compartment. In particular, the controller board that runs the jacks gets in the way of removing the right-side battery cover. You can somewhat see this in Figure 3. Unfortunately, the maintenance of flooded-cell batteries can be a recurring task during periods of heavy use and the ability to access the batteries for water replenishment is important.
I was afraid that I was going to rip a wire loose from the controller board or tear the furnace duct tube in the process of removing the battery cover. As mentioned earlier, it is nearly impossible to access the right-most screws on the right-hand battery box cover. Wow, what a painful experience! Then I had to figure out how to get it all back together โ€“ an equally painful experience! I swore profusely and had to walk away a few times to cool down.
Honestly, I have never seen such a terrible layout. The technician who did the battery installation at my dealer had a very negative opinion about the battery compartment when he gave me the pre-delivery walk-through. I didnโ€™t fully appreciate what he was saying until I had a chance to experience it firsthand. I quickly came to share his opinion. We are not alone โ€“ there are many mentions of the 855 battery compartment on the RV.net and Lance Ownerโ€™s forums. Several people have posted that they decided against purchasing an 855 because of it.
I have a few ideas on what might be done to make things better.
  • Factory install AGM batteries which have zero maintenance or factory install flooded-cell batteries with a battery watering system so they can be maintained without having to take the battery covers off. That way the battery covers only have to be removed every five years or more when the old batteries are changed out for new ones.
  • Place a door on the front side of the camper that provides access to the batteries from the outside. It would be much easier to get the battery covers off if they could go forward and out a door.
  • As long as you are at it donโ€™t just put a door, put a slide-out tray. Make it an option and charge for it. I know I would pay for it.
  • As the screws that hold the two halves of the battery boxes together are difficult to access, install battery boxes that use a strap instead of screws.
  • Move the jack controller board to another location or have Atwood redesign it such that it is smaller and can be located in an up-down orientation. The current slanted orientation and large size is the main source of the maintenance access problems.
  • Raise the height of the compartment another inch and/or extend it another inch so that the jack controller board can be located at a better angle and avoid interference with the battery box cover.
  • Get rid of the excess 20 ft. of telephone cable inside the compartment. That was one of the first things I did as it tends to get in the way. Surely you can get that cable built to a custom length.
Conclusion
All complex systems have tradeoffs in design but safety must always come first. Maintenance of flooded-cell batteries can be a frequent task during periods of heavy use and the ability to access the batteries for water replenishment is critical. At it is, the battery compartment of the 855 product is a maintenance headache and a product liability lawsuit in the making. It is a blemish on an otherwise outstanding product. People are talking about it on the forums and their words are quickly spreading. Sales have been lost because of it.
Mike Stanbro
Portland, OR
121 REPLIES 121
Jfet
What exactly are the lower hoses venting? Hydrogen goes up...
AnEv942
Were the lower hoses attached to the bottom of boxes or just venting the space, though looks like clamps on ends.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
Ski_Pro_3
thanks for the photo Jumbo!
JumboJet
For all you Lance 1050, 1050S owners - and maybe even your Lance camper - I removed the lower half battery box and took these pictures. The two hoses from the bottom 1/2 connect to a 1-1/2" Tee and then a hose runs the full length of the floor to exit the rear via an installed vent.
With the battery box sealed and the vent hoses from the top half to outside vents, I would think we are safe.
JumboJet
Back to the installed battery boxes on my Lance 1050S.
With the upper hoses in place; the lower hoses in place; the grommets for the wires entering from the top in place; and the two halves sealed together correctly; and sealed AGM batteries; Why should I expect anything to go wrong?
If your setup is not like this, either fix it yourself (liability issue?); have a dealer fix it according to Lance instructions; or do nothing and hope for the best.
AnEv942
Most of the folks I know that run Optimas in there rig (4-wheeler) is because of replacement ease & availability-can be found just about anywhere, folks just know the name. That said usually when someone loses a battery more than likely its an Optima (course partly due to so many are running optimas). Generally just stop holding charge or just quit-deader 'n door nail without prior signs. I know for a few years a lot of folks were having problems with them leaking at the posts.
Likely just luck, my aux jeep battery is an optima. It has got to be pushing 10 years old. Never had an issue with it, and its lived an abused life. Ill probably change it this summer, I may look other brands because of the short life Ive recently been seeing though more than likely it'll be an optima. All I want in the jeep is something that works if I happen to be laying on my side, optima still a viable option in it, camper I think there are better options.
But back to the Battery Compartment Safety Issues - I don't think box would be Riva (or Lance) approved if a wet cell battery is installed, dealer cuts the top open for ease of wiring defeating box purpose and its setting next to a possible source of ignition? Pretty much uses up any safety margins-
which is what this thread brought to awareness.
Folks just need to inspect/address as needed.
sleepy
JumboJet wrote:
sleepy wrote:
As always, I checked with my expert:
He wants to know, "Was your Optima AGM battery wired in backwards?"
He went on to say that may have caused the damage (that you reported in a previous post) to your Optima battery and that could have been the reason that it wasn't warranteed. ( customer at fault )
I hope that no one was hurt
I have been wiring batteries since my dad bought me my first Erector set in 1956.
Nevertheless, it was on a Lance 1055 for a few months before I swapped it out for Type 31 sealed battery that is still being used today - 3 years later. Baffled me because I always go with what I consider quality merchandise.
Jumbo Jet,
Actually my electrical engineer and I thought that maybe the RV dealership may have had one of their employees install it... not all of them are skilled. That was after reading the following from a previous post where you answered the OP's question. Please notice the bolded portion where you mentioned an Optima battery.
You said:
I had 1 year old AGM batteries in the TC I traded in and requested they swap them for me. I have always purchased Marine Deep Cycle 1000 CCA AGM Type 31 batteries for my RVs.
I did purchase an Optima battery that was recommended by an RV dealer that swelled and leaked.
Since then, I have bought my AGM batteries at O'Reilly Auto Parts. The past 10 years, I have purchased 6 total. The current set is 4 years old and will be moved to my Motorhome this weekend. I am picking up 2 new batteries at O'Reilly this afternoon. I purchase in pairs for equalization purposes.
And so, JumboJet:
I'd like for you to please notice, I haven't recommended any brand of AGM... and I haven't tried to make any brand of AGM look bad, that would not be right.
My recommendation... is the largest battery that will fit the available space and the one with the most capacity. Our TC's don't get that much vibration , I have tested the highways and by ways all over North America... north of Mexico.
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
JumboJet
sleepy
JumboJet wrote:
sleepy wrote:
I live in an area where there are very large numbers of off-road vehicles... 4x4 golf cart looking4 wheelers... jeeps and hummers (they had an even here several years ago that had 5000 hummers.
The majority of the jeep types and hummers use the Optima AGM's (Jumbo'd failure is the only one that I have personally heard of failing like he reports)
They are the hardiest of all batteries.
The off roaders like the optimas because they are so hardy... they are absorbed Glss mat... spiral would... they layers won't seperate no matter how much thery get banged arournd. This also the reason they look like a 6 pack of coka cola... it is also the reason that the Optimas have about 25% less capacity.
Since we humans cannot build anything perfect, I am sure there are others that have failed. I understand that the original manufacturing plant was moved to a lower cost manufacturing facility in a lower wage Country. Not to say they are not manufacturing to a rigid set of specs. But I will never spend $300 for a battery that the warranty was disallowed.
sleepy
skipro3 wrote:
There isn't anything technically different with one 12 volt battery or 2 6 volt batteries. When a battery fails, it's usually one cell in the string, not the whole battery. The redundancy is in 2 12 volt batteries, I understand that. But my bet is that if one of the 12 volt batteries fails, you are not going to notice it quick enough to save the other battery from being damaged. What a 6 volt battery gets you is less plates that are thicker and therefore more rugged to the jostles and bumps of traveling. The highways are worse than the back roads these days too!
So here's what I do, since I've been running 6 volt batteries; I have a cut-over switch from my truck, which has 2 12 volt batteries. Either one can start my truck, so I installed a disconnect on them. Now, if my 6 volt series batteries fail, I switch one of the under hood batteries over to the camper and I isolate the remaining battery to serve the truck on it's own.
The bottom line is; 2 6 volt batteries can store more energy in the same foot print as 2 12 volt batteries and have less chance of failure due to their heavier plate design. It's much less likely that a 6 volt battery is going to fail compared to a 12 volt battery.
Someone a page or so back asked if I checked with two or three electrical engineers before I did something... actually, I do.... and chemists, and mechanial engineers... even fire protection engineers depending on what I am doing.
I designed and built experiments for a living for more than 30 years.... we designed in safety and built in system integrity...
Two 12VDC batteries are always better in a 12 VDC syatem.
And, AGM batteries are always better that lead acid batteries... and even better, spiral wound, maintaince free, AGM 12 VDC batteries are quantum levels better that any lead acid batteries ever made... lead acid batteries are at risk with boiling acids, hydrogen gasing, corroded connections, imminant danger of explosions, etc.
Rube Goldberg systems make my head hurt... and they are almost always dangerious.
Ski_Pro_3
Jumbo; my 2012 Lance 855S has a different pair of battery boxes. They look like this;
There is no vent in the bottom half and no knock out or other fitting for a vent either. I've got to get in there and remove mine and see where the rear vent is really going to, since it's not connected to the battery.
Ski_Pro_3
sleepy
I have two 12 VDC batteries under the hood of my GMC duramax/allison diesel truck, why don't I use two 6 VDC golf cart batteries in series in their place?
Off road vehicles have 12 VDC batteries, why don't the off roaders use two 6 VDC batteries in their vehicles?
Not many people use their truck campers as much as Janet and I do (1032 nights, 67,000 miles, all off the grid), why don't we use two 6 VDC golf cart batteries in series in our camper?
Note: We totally depend on our onboard electrical system every minute that we are in the camper. I doubt that anyone has a more sophisticated electrical system in their camper than we do or use all of theirs more.
The answer to all three questions is the same:
With a cobbled up system using two 6 VDC batteries wired in series to operate a 12VDC vehicle or a 12VDC truck campers system gaurentees failure when one of the 6 VDC batteries fail, the survivor would be usless.
The four wheeler would be stranded many miles from safe haven if one 6VDC failed...(one 6 VDC battery would be worthless)
We would be stranded if our truck didn't have a good source of 12 VDC to turn over that big diesel engine when we are in some of the very remote areas that we go (one 6 VDC battery would be worthless.)
All of that sophisticated electronis equipment in our camper would be worthless without 12 VDC battery storge... The PVsolar panels would be worthless without a place to store their output, the inverter won't run on 6 VDC, The fridge computer requires 12 VDC, I couldn't even start the built in generator with 6 VDC if one of the two 6 VDC golf cart batteries in series failed.
I can think of a 1000 reasons to have two good 12 VDC batteries but I can't think of a single reason to own a pair of 6 VDC golf batteries wired in series when one of them has failed. I don't have a single thing that will run on 6 VDC.
Just another something to think about.... don't you think?
Sleepy
JumboJet
JumboJet
Update after inspection of Lance 1050S battery containers:
Since I was installing new AGM batteries in my Lance 1050S, I decided to inspect the battery container for the second hose. There is a hose attached to the bottom of the container that exits "somewhere". I didn't disassemble the container or the TC to determine exactly where it eventually goes.
Undoubtedly this design is good enough or has been working well enough to keep from burning down or blowing up TCs.
Note: Meets RVIA Code
